Old 11-05-2009, 03:33 PM   #1
sailed2japan
Jonny
sailed2japan's Avatar
Steel Bed Floor?
Has anyone ever put a truck together with a bed and used a steel floor? How did you or would you build the floor? I was thinking about doing this and using a 73-87 bed floor.
1966 C30, Cummins, stacks, and a flat bed in progress...
"Honor.....simply put,
A veteran - whether active duty, retired, national guard or reserve is someone who, at one time in his life, wrote a blank check made payable to 'The United States of America', for an amount of 'up to and including his life.' That is Honor, and there are way too many people in this country who no longer understand it."
-AEC Hundley USNR
sailed2japan is offline   Reply With Quote
Old 11-05-2009, 03:40 PM   #2
61TWUK
61TWUK's Avatar
Re: Steel Bed Floor?
Mine has a steel floor... but its not out of another truck... its just two sheets of steel.
1961 Apache
SWB/SBW for now...
Built 327
You need two tools in life: duct tape and WD-40. If it moves and it shouldn't, you use duct tape. If it doesn't move and it should, you use WD-40.
61TWUK is offline   Reply With Quote
Old 11-05-2009, 04:29 PM   #3
markeb01
Senior Enthusiast
markeb01's Avatar
I used diamond plate aluminum for mine, although there have been times I wished I'd used steel diamond plate instead just to increase the weight on the back half of the truck.
To build the floor I used a piece of 3/4" marine plywood the same width as the floor, then split it down the middle so I could slip it under the angle rails on the sides, leaving a joint down the middle. Before installation I coated the wood on all sides with fiberglass resin (no cloth just resin) to completely seal the wood. I then rested 48" wide diamond plate on top and bolted it in place. I didn't have any way to get it under the angle rails, so it's centered and just touching the edges of the rails.
For 10 years I had a Gaylord bed cover installed so nobody could see it anyway. It's certainly not show worthy, but for a working truck it's easy and looks nice. The only pictures I have are very poor quality but show how it looks.
I've crawled under and looked at it and other than having 10 years of road dirt on it, the wood looks good as new with no deterioration.
Old 11-05-2009, 09:39 PM   #4
mbgmike
You can use the floor out of later trucks. I do remember that they can be used their is a little problem but they do work. I will try and remember
mbgmike is offline   Reply With Quote
Old 11-05-2009, 09:54 PM   #5
sailed2japan
Jonny
I guess I should have mentioned that I'll be doing it in a lwb fleet side. That diamond plate bed looks awesome, but the reason I was thinking of doing a steel floor was to be able to have it rhino lined and use it for some light work duties.
-AEC Hundley USNR
Old 11-06-2009, 01:44 AM   #6
Captainfab
60-66 Nut
With some checking and measuring that I've done, the steel floors from the '67-'72's would be a nearly perfect fit into a '63-'66 bed. I have yet to do one but this is what I would suggest.
Old 11-06-2009, 02:20 AM   #7
hill64step
Someone put this in years ago (before i was even born):
I'm getting ready to cut it out. I want to go to wood.
64 Stepside.. A work in progress..
hill64step is offline   Reply With Quote
Old 11-06-2009, 03:05 AM   #8
2tons of fun
i have done one and they are a nearly bolt in deal.
there are some goofy things that go on when the 2 are put together but i did it with free parts that were in so so shape to start with.
2tons of fun is offline   Reply With Quote
Old 11-06-2009, 07:03 AM   #9
LILRED66
LILRED66's Avatar
TX:
Here are a few photos of a '64 GMC lwb fleetside truck with a steel diamond plate bed, done by the previous owner. It is not show-quality, but super durable.
I like your idea of a factory steel bed floor, as a donor. I think, if done correctly, would look nice.
LILRED66 is offline   Reply With Quote
Old 11-06-2009, 11:40 AM   #10
ob1monkey
I used a 70 lwb fleetside bed floor in my 66 the only thing I found was a spacer about 3/4 inch is needed at the front panel/ or you could move the lip up to accomidate. I will try to post some pics tonight.
ob1monkey is offline   Reply With Quote
Old 11-06-2009, 01:21 PM   #11
62 short step
62 short step's Avatar
Yes pics would be good! This is what i've been wanting to do.
www.louisianaclassictruckclub.com
1965 c-10
86 chevy c/k 20
62 short step is offline   Reply With Quote
Old 11-06-2009, 01:27 PM   #12
Clyde65
Clyde65's Avatar
put the wood in it! Rhyno line the sides, front and tailgate. then when you need to haul something, roll out your trusty bed mat. this is what I do, the bed mat doesnt stay in the bed, I like my wood and this has kept it nice for years.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 11-06-2009, 06:07 PM   #13
hill64step
If you're looking into spray in liners go with Line-X. It may cost a little more than Rhino, but I promise you it's worth it.
Old 11-06-2009, 06:11 PM   #14
ob1monkey
this one shows the body lines after the steel floor
Old 11-06-2009, 07:00 PM   #15
62 short step
From the pic the body lines look good, did you have to ajust the bed to get them right?
1965 c-10
86 chevy c/k 20
Old 11-06-2009, 07:01 PM   #16
ChopperDr
That floor looks like it was made to go in there. I need to find one for mine.
ChopperDr is offline   Reply With Quote
Old 11-06-2009, 07:54 PM   #17
ob1monkey
surprisingly no it lined up fine. I did however have to slightly drill out the holes in the frame. But that may be due to the hitch I welded in the frame.
Old 11-06-2009, 08:02 PM   #18
62 short step
Cool! I've been looking for awhile but had no luck finding one, yet.
1965 c-10
86 chevy c/k 20
Old 11-06-2009, 08:10 PM   #19
ob1monkey
I got mine off craigslist and then just hoped it was going to fit. I had a lead on a 73-87 bed but thought the 67-722 would line up better due to the frames being almost identical. .
Old 11-09-2009, 03:46 PM   #20
sailed2japan
Jonny
Awesome info guys thanks for the input.
ob1monkey: Can yopu take some close ups of the spacer to show where and how itwas installed?
-AEC Hundley USNR
Old 11-09-2009, 05:33 PM   #21
LeftCoast32
Custom Builder
LeftCoast32's Avatar
I also have a 67-72 Long Fleet Floor that is going in my '66 Long Fleet Bed. I will take pictures when we are assembling it.
LeftCoast32 is offline   Reply With Quote
Old 11-10-2009, 01:47 AM   #22
94tx
94tx's Avatar
I did not install it, but if I remember correctly the PO said it was out a 73-87 truck, looks like it lined up perfectly. I would get better pics but my truck is back at the parents while I'm at school.
94tx is offline   Reply With Quote
Old 11-10-2009, 02:10 AM   #23
63whoopie
I am interested in putting in a steel floor in my shortbed stepside.... figured I would have to get a bed floor and cut it down. Just found a listing on Craiglsist for a "70's 80's stepside bed for sale or trade" for $85. Is it possible to just switch the fenders and run that bed? (it will have metal floors, right?) I won't buy it just for the floor; poor college kid.
63whoopie is offline   Reply With Quote
Old 11-10-2009, 08:55 AM   #24
lakeroadster
Yes and No
Yes... you can swap out the fenders but you also need to swap out the correct steps also as they match the fender style,
No.... I think all step-sides in the era you mention had wood floors.
My '65 had a '67-72 bed when I bought it and it had a wood floor. I put 58-66 fenders and steps on it.
lakeroadster is offline   Reply With Quote
Old 11-10-2009, 09:49 AM   #25
ob1monkey
It goes under the steel floor between the lip on the front panel and floor pics would be very dificult to see from underneth. it's to make up for were the wood should be.
