Old 04-29-2018, 01:46 PM   #26
_Ogre
_Ogre's Avatar
Re: Battery location
behind the pass seat in truk since 2010, no box, no vent, just the battery
the cover with the finger hole, cover held in place with velcro
just swapped out the battery 2 weeks ago, easy to get to
shop air compressor timer
Old 04-29-2018, 02:40 PM   #27
Matt_50
Thanks guys, I've got some food for thought. I think I was also overthinking if the battery needed to be protected from water and road debris. Mine looks like a hacked up version of Black Sheeps. If I go factory spot route, I'll need to make of buy a new shelf.
1950 Build
Matt_50 is offline   Reply With Quote
Old 05-18-2018, 11:31 PM   #28
mobileortho
mobileortho's Avatar
I was going to put it behind the seat but opted to mount it to the firewall.
Robert C.
1950 3600
3600 re-do, shortening it up
If it's true what they say, "You learn from your mistakes,"
I'm a Genius in the making.
mobileortho is offline   Reply With Quote
Old 05-19-2018, 01:14 PM   #29
_Ogre
_Ogre's Avatar
ironic that the AD guys move them under the hood and the TF guys move them out from under the hood
Old 05-19-2018, 01:52 PM   #30
joedoh
joedoh's Avatar
that IS ironic
I like them under the hood, big cables and connectors can be a big expense.
Old 05-19-2018, 02:19 PM   #31
Matt_50
I'm not very picky on location. Under hood seems more convenient.... my concerns were how to carpet floor and still use factory spot, or how to put under hood and be able to install ac/heater too.
I had thought of the wires and connectors... is there that much of a cost difference between under hood, in cab, or under cab?
1950 Build
Old 05-20-2018, 01:05 PM   #32
duramax55
no pic but i am doing a 55 2 chevy with a duramax with 2 batteries they are side by side inside the frame and can be removed from under the truck. They are at the tail end of the trans, and under the cab
duramax55 is offline   Reply With Quote
Old 05-21-2018, 06:40 PM   #33
Black_Sheep
Black_Sheep's Avatar
If you are buying new cables the incremental cost is minimal. The biggest expense would be some kind of drop down battery box if you choose to keep it under the cab.
Black_Sheep is offline   Reply With Quote
Old 05-22-2018, 11:06 PM   #34
PDW HOTRODS
PDW HOTRODS's Avatar
No dif in cable. AD bat is very close to the starter, no need for longer cable.
PDW HOTRODS is offline   Reply With Quote
Old 05-24-2018, 09:57 PM   #35
Dan in Pasadena
Dan in Pasadena's Avatar
Originally Posted by my56chevytruck View Post
Matt,
This is a question I asked when redoing my 56, stepside, and there were multiple pros and cons to just about every location. I chose to remove the battery from the firewall, only to have a cleaner look when looking at the engine compartment, but I got some boos when I said, "behind the seat". Just make sure the battery box is a good one and is secured to the floor. So, you choose what is the best location, my reasoning is I want access to mine and a good looking engine compartment, my opinion solely.
This is what I did too except mine is more on the driver side and not in a box. It’s an AGM battery.
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
