01-19-2015, 03:20 AM | #1 |
between fender well and bedside..welt or no?
hi. i am redoing my bed wood on the 68 fleetside.
i took the fender wells off obviously. it looks like they may have had some seam seal or some putty material? should i be reinstalling anything between the bedside and well...like welt or caulk or specific seam sealer or just leave a gap for water runoff to prevent rust? any opinions welcome...thanks.
Every new beginning comes from some other beginnings end |
01-19-2015, 12:43 PM | #2 |
Re: between fender well and bedside..welt or no?
If you want original, there was a caulk-like material in there that was not visible when assembled. I suggested to the shop that did the body of my truck that they use ribbon caulk like that used on RVs. They used something else that body shops use. No reason why the RV type caulk wouldn't work though. However, you probably don't want it to ooze out. Probably not necessary though.
01-19-2015, 01:20 PM | #3 |
Moderator
I omitted it when I restored my truck.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
01-19-2015, 01:43 PM | #4 |
All about them K’s
I personally would put some seam sealer in there. As water gets in there over time it will rust, whether there's paint or no paint. The seam sealer is just one more barrier to help keep the rust at bay.
In the desert you can probably do fine without it but in a wet climate I wouldn't skimp.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
01-19-2015, 02:37 PM | #5 | |
01-19-2015, 03:19 PM | #6 |
My recomendation as well!
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
01-19-2015, 03:36 PM | #7 |
Yes, i would do it.
Shawn 68 chevy K/20 05 chevy 3/4 4x4 71 short step-sold 71 chevy Beauville van My build. http://67-72chevytrucks.com/vboard/s...d.php?t=633039 |
01-19-2015, 03:40 PM | #8 |
Put something that is paintable.
Ron
Member #111 68 C-10 Daily Driver 70 4x4 Project 76 Jeep CJ-5 Help Support the Board: http://67-72chevytrucks.com/vboard/payments.php He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors. Thomas Jefferson |
01-19-2015, 03:51 PM | #9 |
thats the type of thing i was looking for. thanks. wont need to be paintable as the truck is already painted...i will just scrape off the old stuff (could be that as it looks grey) touch it up with blk paint and add that stuff. i assumed would help with vibration and metal to metal contact when the bed flexes
01-20-2015, 02:44 PM | #10 |
Yes, replace it . A repro. cloth felt like welting is made through one of the major vendors. Specifically for this. Which one? Clean it up,apply some rust converter,then seal,re-assemble
David |
