Old 02-15-2011, 08:23 PM   #1
dsy1
fan belt squeal?
All is fine until I get to about 2800 RPM on the highway, then I get a loud squeal that I assume is from a fan belt. I have tightened both belts (one for alternator and one for power steering) but it didn't solve the problem. (I know the expensive solution is to get an overdrive transmission so I don't need to run at 3000 RPM, but with 4.11 gears and a non-overdrive TH350 I have to work with what I have).
Next step is to remove one belt at a time to try to find out which one is making the noise. Both the water pump and alternator are new, so it should not be shaft/bearing problems. Any other ideas?
dsy1 is offline   Reply With Quote
Old 02-15-2011, 08:33 PM   #2
72chevyk10
I built it
72chevyk10's Avatar
Re: fan belt squeal?
tried belt dressing yet? thats worked for me before
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness
'98 dodge 3500 12v 5sp 4x4. the truck that actually runs
I think the best and cheapest performance mod is to have someone that knows what the hell they are doing perform a tuneup on said vehicle.
72chevyk10 is offline   Reply With Quote
Old 02-15-2011, 08:50 PM   #3
Rev it up like that while you watch the belts and pulleys under the hood. I wonder since they are slipping at a steady high rpm,and not when you "snap" it,if there isn't an alignment problem causing the belt to not ride deep enough in the pulley. I have had a chronic belt slip when I revved the motor and using a deep groove Z/28 pulley on the alternator solved it. It was misaligned just a bit and I never could get it quite right. Never did figure it out.
Old 02-15-2011, 09:28 PM   #4
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Unfortunately, belt dressing has not worked for me. If you can safely hold a bar of soap against each belt (one at a time so you can find the culprit), it will temporarily stop the squealing. Obviously keep your fingers, knuckles, clothing etc. out of belts & pulleys....
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 02-16-2011, 12:21 AM   #5
dsy1
The belts are the kind with the notches on the back side, maybe I'll try another brand if I can't solve it some other way. A little narrower wouldn't hurt, it would fit down in the groove a little better.
Old 02-16-2011, 12:28 AM   #6
leddzepp
Moderator
leddzepp's Avatar
Oops....sorry for editing your post above...I meant to hit the quote button
I agree, the deeper the belt sits in the pulley, the more "grab" it has, and the less likely to slip. In fact, I would be willing to bet that WILL solve your problem. It did in my case.
Belt dressing has NEVER worked for me, only made the problem worse. Carefully holding a bar of soap along the edge of the running belt as Stocker described above has worked many times for me...however it is only a temporary fix as stated.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 02-16-2011, 02:26 AM   #7
5150.4.67
Make sure the belt isn't bottoming out on a severely worn pulley. This is evidenced by a shine on the bottom side of the belt......
5150.4.67 is offline   Reply With Quote
Old 02-16-2011, 03:12 AM   #8
swamp rat
swamp rat's Avatar
Heres my delema, i have brand new pullies on the crank and water pump, a new alternator with new pully, i have test ran the engine without the pullys and get no squeal at all, i only get squeal with the alternator belt as i have tested with just one belt then the other. I have tryed both running a little too tight and a little loose.. I can see no visable sign's of missalignment.. I have tryed both Gates and Dayco belts to no avail.. My only other possible thought is that the 4X4 3/4T trucks supposably use a smaller diameter water pump pully from what i have read than the 1/2T to increase waterflow, so maybe the smaller pully creates more drag and is the source of the squeal? I plan to try a fan clutch some day to see if that helps.. yea its a pita for sure..
EDIT: Try using the search feature and type in belt squeal and you should find more threads on the subject.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 02-16-2011, 09:30 AM   #9
It's usually at the alternator that they slip since that's the smallest pulley. You guys should try the Z/28 pulley. It helped me. They are designed for just this problem with hi-performance motors. They are deeper and solid. I don't a picture or I'd show you.
Old 02-16-2011, 10:43 AM   #10
1970 Bowtie
It's all in the timing
1970 Bowtie's Avatar
dsy1,you said you replaced the water pump and alt.When you installed the belts were your hands free of grease(clean).Kind of an obvious question but just a thought.
The Dude Abides.
I aint sayin, I'm just sayin.
1970 Bowtie is offline   Reply With Quote
Old 02-16-2011, 01:54 PM   #11
swamp rat
swamp rat's Avatar
Where would i find such a pulley?
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 02-16-2011, 02:29 PM   #12
bajaracing
bajaracing's Avatar
i had a simular stubborn squeek with my power steering. No dressing would solve the problem. Ended up beign slight mis-alignment. Pulled the pump, added a spacer so it lined up perfectly. Problem has completely gone away.
bajaracing is offline   Reply With Quote
Old 02-16-2011, 02:56 PM   #13
Shane
Shane's Avatar
if a belt squeals normally it's a good sign that it needs to be replaced ...
Shane is offline   Reply With Quote
