Old 01-08-2004, 04:32 PM   #1
toddol1971
Question eaton rear axle
does any one know where to buy axle bearings,seals for the eaton rear axles. I have a 68 c 20 & a 71 k 20 with this behemoth. Also does any one know anything about these, I think there were 2 different model #'s like HO 52 & HO 72. Any help would be great. Also any expoided views of this would be great, cause i want to rebuild the one on the 71 k20 thanks
toddol1971 is offline   Reply With Quote
Old 01-08-2004, 05:28 PM   #2
69k5
dp a search for my name and you will find the bearing numbers and if you go to www.coloradok5.com and do a search for my name or eatonyou will come up with a lot of info. bearings are cheaper through a bearing place versus a parts store. or pm me and i will get you all i can. just dont have the time right now.
69k5
69k5 is offline   Reply With Quote
Old 01-08-2004, 07:15 PM   #3
toddol1971
thanks 69k5. Im in the same no time boat.
All my trucks are gone now. I'll gladly take a free one
Old 01-09-2004, 01:58 AM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
The HO52 was in 3/4 ton trucks while the HO72 was a one ton rear.
You tried NAPA on those bearings?
Old 01-09-2004, 12:27 PM   #5
COBALT
COBALT's Avatar
NAPA = good luck! I got no love from them on both of my HO52/72 axles.
Try these guys:
Randy's Ring & Pinion
They helped me get my working axle back together...
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 01-09-2004, 01:35 PM   #6
toddol1971
thanks, i tried napa with no luck. They said they would need the old bearings & seals. I said no sh**, if I took them out i could probably get them at the local bearing warehouse. thanks again
Old 01-09-2004, 03:01 PM   #7
69k5
take this to na[ anmd tell em to read the book. got this from napa online. put in for my parts truck and wholla 72 k20 rear axel
NAPA Bearings Differential Bearing - Rear Axle
Usually ships in 24 hours. BRG
KD11786Y $ 44.99
w/ H052, H072 Axles
NAPA Bearings Pinion Bearing - Rear Axle
A1011 $ 329.00
w/ H052, H072 Axles, Front
Usually ships within 3 to 5 days. BRG
M5205UV $ 41.49
w/ H052, H072 Axles, Rear
NAPA Bearings Differential Bearing Cup - Rear Axle
382S $ 16.69
w/ Spicer/Dana 60, 60-35 Axles
BR382 $ 17.49
w/ H052, H072 Axles
LM501314 $ 6.49
w/ 8.50" Ring Gear
NAPA Bearings Differential Bearing Cone - Rear Axle
387A $ 19.99
388A $ 27.99
w/ H052, H072 Axles
LM501349 $ 13.49
w/ 8.50" Ring Gear
NAPA Bearings Pinion Bearing Cone - Rear Axle
HM803146 $ 28.49
w/ Spicer/Dana 60, 60-35 Axles, Rear
69k5
Old 01-09-2004, 03:04 PM   #8
69k5
page 2 from napa online
HM88542 $ 19.49
w/ Spicer/Dana 60, 60-35 Axles, Front
NAPA Bearings Pinion Bearing Cup - Rear Axle
HM803110 $ 17.49
HM88510 $ 9.99
NAPA Gaskets Axle Housing Cover Gasket - Rear Axle
Usually ships in 24 hours. NGA
P27768T $ 4.69
P27768TC $ 7.49
Tuff-Cork
NAPA Gaskets Differential Carrier Gasket - Rear Axle
P29129 $ 3.69
Powerglide Bearings Differential Bearing Cup - Rear Axle
Usually ships in 24 hours. PGB
P382S $ 9.49
PLM501314 $ 4.29
w/ 8.50" Ring Gear
Powerglide Bearings Differential Bearing Cone - Rear Axle
P387A $ 10.99
PLM501349 $ 7.49
w/ 8.50" Ring Gear
69k5
Old 01-09-2004, 03:10 PM   #9
69k5
courtesy of rod from one of my post theses are the hub bearings and they are timken part numbers
188930 inner bearing
188932 outer bearing
1962 to 1972 used the same ones.
Old 01-11-2004, 02:55 PM   #10
toddol1971
thanks again some of that stuff is pricey huh. I tell ya if these rear ends werent so strong id be looking into a 14 bolt with discs from boyce equipment, it still might be cheeper cause i want to conver mine to rear discs. such decisions we face il just shut my head in the door a few times till things go black
Old 01-11-2004, 03:17 PM   #11
69k5
the same rear disc for a 14ff works on an eaton. bolt on kit. checkout azkickin.com good people and its a bolt on kit.. 80 bucks for the brackets and then jy and get some cheap calipers and 1 1/2 of work easy aspie.
69k5
Old 07-05-2009, 12:36 AM   #12
capev86
Re: eaton rear axle
just get a 14BFF axle from a 2000+ chevy w/ factory rear disc.....its tuned for the back end and has proper drum parking brakes unlike those aftermarket kits that just use front calipers from whatever car. you'd just have to fab the proper mounts for the trailing arms, track bar and shocks. the 2000+ 14BFF has an 11.5 ring gear and is massive compared to the 10.5 ring gear 14BFF's in 70's to 90's trucks. i may some day just swap the gm rear disc brakes onto my HO52 on my 72 burb. it will be a neat combination of modern and classic.
capev86 is offline   Reply With Quote
Old 07-05-2009, 01:45 AM   #13
ERASER5
ERASER5's Avatar
Re: eaton rear axle
That is some serious thread resurrection right there!
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 07-05-2009, 01:54 AM   #14
capev86
Re: eaton rear axle
yeah.....found it while searching the net for info for my suburban.....didn't realize it was so old.....
Old 07-05-2009, 08:22 AM   #15
WorkinLonghorn
WorkinLonghorn's Avatar
Re: eaton rear axle
Wow, I read this entire thread not even realizing that it was written on papyrus.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent.
WorkinLonghorn is offline   Reply With Quote
Old 07-05-2009, 10:37 AM   #16
Longhorn Man
Re: eaton rear axle
lol!!!
Old 08-20-2009, 04:37 PM   #17
vectorit
What?
vectorit's Avatar
Re: eaton rear axle
EDITED:
I have learned so much about my Eaton these last few months.
K20's at least for my year of burb 1968 were 12" drums, and very difficult to find drums and brake parts for.
No, Napa does not carry them anymore.
I discovered that the adjuster arm on a 1974 14 bolt, is the same for the 12" drumed Eaton and closed knuck Dana 44.
I'm back in business!
Chris
1968 K20 Suburban
1972 K10 LWB PU
Last edited by vectorit; 10-20-2009 at 06:59 PM. Reason: Removed confusing post, and replaced with more factual info.
vectorit is offline   Reply With Quote
Old 08-21-2009, 06:48 PM   #18
toddol1971
Re: eaton rear axle
go to napa
Old 08-21-2009, 08:02 PM   #19
vectorit
What?
vectorit's Avatar
Re: eaton rear axle
Originally Posted by toddol1971 View Post
go to napa
Napa doesn't carry them anymore.
Chris
1968 K20 Suburban
1972 K10 LWB PU
Old 08-22-2009, 08:53 AM   #20
toddol1971
Re: eaton rear axle
well then take them to a motion industries or find one on the web, call them tell them what you got & have them ship it to you. You will need the numbers on the bearings & seals or the exact measurements.
Old 08-22-2009, 05:49 PM   #21
vectorit
What?
vectorit's Avatar
Re: eaton rear axle
NOT talkin about a bearings or seals...
Chris
1968 K20 Suburban
1972 K10 LWB PU
Old 08-22-2009, 05:59 PM   #22
leddzepp
Moderator
leddzepp's Avatar
Re: eaton rear axle
Did you try Napa?
Sorry...had to do it. Good luck in your quest!
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 08-22-2009, 06:49 PM   #23
vectorit
What?
vectorit's Avatar
Re: eaton rear axle
Yessssss I did. Plus all the other local chain parts stores.
Plus I thought I had some mad google skills, and I still can't find a parts house that sells 12" brake drum parts. Shoes, yes. Wheel cylinders, yes. Springs seem to be interchangeable from 11" to 12", so I have all new parts except for this stupid adjuster arm.
Heck Inline Tube is putting a copy of my E-brake cable into their catalog now after being able to copy mine, since the one they were selling for a 67-72 was for an 11" brake drum.
Chris
1968 K20 Suburban
1972 K10 LWB PU
Old 08-25-2009, 03:14 PM   #24
SoCal71K20
Re: eaton rear axle
vectorit- There's a place down here in Spring Valley called Border Parts, sorry I don't have their number on me right now. They carry early eaton rear axle bearings, seals, etc. Probably hook you up with other eaton needs as well. Good luck.
SoCal71K20 is offline   Reply With Quote
Old 08-25-2009, 03:21 PM   #25
SoCal71K20
Re: eaton rear axle
Also, If I remember right, when I rebuilt the rear drum brakes on my 71 K20 I discovered that year was an odd ball as far as brake drum was concerned. One drum was turned OK, the other was too far grooved and junk. National Brake in San Diego fixed me up with a replacement 8 lug drum that was too wide but they just trimmed to proper width. What a stout heavy azz axle they are though. Next time, probably cheaper to go with discs.
