Old 12-30-2018, 12:41 AM   #1
chewychevy67
327 exhaust pipe size
I have a 1967 327 300hp I'm going to have completely rebuilt for my short bed 67 truck. May do a roller cam but it will stay close to stock. It's an 400 auto, gear vendors 3:55 rear so it won't be a really high spinner. I have a set of Vette 2.5" ramhorns and my exhaust guy recommended I use them (he says he can make the tight bend work off the manifolds) and do full 2.5" exhaust. Now my question is will this hurt the engines performance? This is a full frame off new build so the exhaust will be new stainless steel mandrel bent. If the stock ones with 2.25" would be better I'd rather do what's right 1st time around. No towing or racing, just a cruiser.
chewychevy67 is online now   Reply With Quote
Old 12-30-2018, 12:58 AM   #2
truckster
truckster's Avatar
Re: 327 exhaust pipe size
Free flowing exhaust is not going to hurt performance.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 12-30-2018, 08:25 PM   #3
crazy longhorn
Fabricate till you "puke"
I would go 2 1/2, all the way out back....add an H-pipe to the system, to help with low/mid tork & it will also take the sharp rapp off the duel pipes Best of fun....Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 12-31-2018, 12:36 AM   #4
chewychevy67
Yes he said put an H or X pipe as well. Ok. I just heard that may hurt my down low torque but if it's not a big issue I'll just go with 2.5s all the way thru! Thanks.
Old 12-31-2018, 09:49 AM   #5
kaycee
kaycee's Avatar
Wont hurt a thing to run either 2.25 or 2.50 don't think you could tell a difference in either with or without a balance pipe besides sound wise. Seat of the pants dyno says you wont but if you put it on a real dyno you will see it on paper then. JUST MY OPINION
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327
kaycee is offline   Reply With Quote
Old 12-31-2018, 03:14 PM   #6
Tom
driving is in my blood
Tom's Avatar
They put dual 2.5" exhaust on little 4.0L v8's oem these days, you want at least that with a 5.3L.
Tom is online now   Reply With Quote
Old 12-31-2018, 07:21 PM   #7
truckster
truckster's Avatar
The "you need some back pressure" myth has been around a long time. You don't need back pressure; it's the enemy of torque and horsepower. An engine pumps air; the easier you make it for air to get in and out, the more benefit you're going to get.
Where tube size does matter is in building headers - you need an appropriate size for proper scavenging. With rams horns, you're fine to run 2.5 and you won't suffer any loss of torque.
Old 01-01-2019, 04:07 AM   #8
68post
2.5" headpipes to 2.5" "H-pipe" and 2.5" mufflers then you can drop to 2.25" out thru the tailpipes without a loss. 327, 350 , or small cam 400. Just a suggestion, I built alot of my exhausts in alot of yrs, racecars (2.5" ramhorns) to muscle cars & worktrucks (headers).
Mandrel bends only !
Tim K.
84 K30 srw Silverado 454 auto
85 C20 350 C6P auto flatbed
94 K1500 lifted shortbed 350 4 bbl NV4500
68post is offline   Reply With Quote
Old 01-10-2019, 01:58 PM   #9
Tom
Tom's Avatar
But why drop the size at the end?
Old 01-10-2019, 04:09 PM   #10
68post
You do not have to , but it will not hurt anything either.
It can help maintain a little more velocity and be easier to find tailpipes (should cost less too).
Tim K.
