Old 05-15-2018, 06:52 PM   #1
MacQuigley
Fitting Bed Wood
I'm needing to trial fit the wood for my bed in order to check the fitment of the sides etc.
Unfortunately when I got my truck it came with a bit of old ply in the back, literally in the back as it wasn't fixed down to anything.
Could some kind sole post up some pictures of a step side's bed just so I can see the layout. The closest C10 to me is over 100 miles away, so I cant just pop round for a look see!
MacQuigley is offline   Reply With Quote
Old 05-15-2018, 09:11 PM   #2
Clyde65
Clyde65's Avatar
Re: Fitting Bed Wood
Does this help?
http://www.lmctruck.com/icatalog/cbe/full.aspx?Page=74
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 05-16-2018, 09:03 AM   #3
The Rocknrod
Moderator
The Rocknrod's Avatar
Just FYI - the FAQ section has the following information:
Bed Wood:
Post your Bed Wood/Metal - Customized/Modified or Stock
Black wood beds!!!! Pics Please : September 2011
1965 wood bed floor - DIY : September 2014
Wood Bed Patterns
Making My Own Bed Wood-Equal Width Boards?
64 C10 bed issues : May 2014
replies include various photos of the bed wood, strips, etc., on a fleetside bed.
questions and answers about bed fitment, with photos
Synthetic Wood Bed Install / short stepside : October 2013
Milling bed wood
Bed wood stain color
Wood Bed Finishing 101
Bedwood/bed floor ideas and pictures
Wooden bed replacement ideas??
What size wood for bed on a 61
Old 05-16-2018, 04:50 PM   #4
MacQuigley
Bed Wood:
I'm really useless at this! I keep forgetting about simple things like the FAQ section of this and just about every other forum Ive ever been on!
Old 05-16-2018, 05:43 PM   #5
The Rocknrod
Moderator
People forget. I'm just trying to be helpful. I'd forget my head if it weren't attached.
Old 05-16-2018, 06:09 PM   #6
MacQuigley
Hee hee! Id forget my head if it wasnt for the bolt through my neck!
Old 05-30-2018, 04:31 PM   #7
MacQuigley
Been looking through the FAQ section to see if there is an answer to another question but I cant find one.
When I bought the new wood for my bed I bought a full set of polished stainless strips including the 2 side angled strips.
In truth Id forgotten Id bought them until I was trial fitting the bed. That's when I realised that the bed sides already have these welded on.
Can anyone who has fitted the stainless angles before tell me, did you have to remove the welded steel strips first and if so how did you attached the stainless strips to the bed sides?
Old 05-31-2018, 12:41 AM   #8
rvrfoot
rvrfoot is offline   Reply With Quote
Old 05-31-2018, 12:45 AM   #9
rvrfoot
Old 05-31-2018, 11:35 PM   #10
forestb
forestb's Avatar
my stepper
forestb is offline   Reply With Quote
Old 06-01-2018, 03:19 AM   #11
MacQuigley
Cheers guy's for the pictures.
One thing I notice right away is that both your beds seem to sit between 1" & 2" higher than mine. Judging by the front panel U can see at least 1" of the pressed section of the cab back?
Are either of your beds raised at all?
Old 06-01-2018, 11:22 AM   #12
forestb
forestb's Avatar
mine is not raised
The angle strips on the side of the inside of the bed should not be sitting on the cross braces. There should be about a 3/4 inch space between those angles and the cross braces that run vertical under the bed there should be wood in between them. You can kind of see what I am talking about in this photo. If there is not enough wood there the bed will be to low
Old 06-01-2018, 11:31 AM   #13
forestb
forestb's Avatar
Here is the photo I meant
