06-21-2018, 10:02 AM | #1 |
embossed bowtie sheetmetal
anybody know where I can get an embossed bowtie about 10-12" to weld into my dash.
www.olesargecustoms.com email: chris@olesargecustoms.com '48 build: http://67-72chevytrucks.com/vboard/s...d.php?t=541904 '33 build: http://67-72chevytrucks.com/vboard/s...=1#post6232888 '49 build: http://67-72chevytrucks.com/vboard/s...=1#post6364475 |
06-21-2018, 03:10 PM | #2 |
Re: embossed bowtie sheetmetal
No one has replied so I will take a shot at it. If you have a local custom car shop or fabrication shop they should be able to make a male and female die to put in a press. If you just want one copy it could probably be made out of hard wood. If more I would go with aluminum billet or steel. Then you sandwich the sheet metal between and press it in a regular shop press. I have not done this but I am sure the others who have done similar thing can correct me on any points I have missed. Can't be that hard I would think.
68' with no bells or whistles unless I add'em. |
06-21-2018, 04:23 PM | #3 |
You can do as Barnfind46 has said. Or find someone that bead rolls, you can see if they can make a one off for you. Check out Atomic Armadillo Metal Fab, he might be able to make something custom up for you.
1967 Chevy C20 to K20 Conversion "Simply Toxic" http://67-72chevytrucks.com/vboard/s...d.php?t=749409 1971 Chevy C20 Custom Camper LS Swap http://67-72chevytrucks.com/vboard/s...d.php?t=763775 |
06-21-2018, 05:38 PM | #4 |
thanks guys
06-21-2018, 05:51 PM | #5 |
Another option is license plates. These will be aluminum but you could use 3M 08116 panel adhesive to bond it to the dash...it will never come off.
1967 C10 Step side 1970 AMX 390 1977 Datsun 280Z highly modified with '95 LT1 power |
06-21-2018, 06:18 PM | #6 |
Look through here, i'm sure someone can do that for you.
https://www.jalopyjournal.com/forum/...144995/page-25 |
06-22-2018, 12:29 AM | #7 |
Check out allmetalshaping.com there are several methods to accomplish making this part. Bead roller, flow forming, Pullmax with a pattern, hydroforming, stamping.
Saskatoon, Saskatchewan Canada |
