10-21-2018, 09:58 AM | #1 |
66 chev C30 panel truck lower rear quarters ?
good morning friends, just introduced myself in the new member section . I just got a 66 C30 Panel . Wondered if anyone knows if rear lower quarter panels for behind the back wheels are available from anywhere ? mine is the longest truck, that panel behind the back wheel is at least 2 feet long . every site i look at , I click c30 panel, but it only shows me rear lower 1/4s for 66 pickups. I may have to make them but thought one of you gentleman my know if some one makes them . Thank you ! Bob
10-21-2018, 11:31 AM | #2 |
Re: 66 chev C30 panel truck lower rear quarters ?
There isn’t any body panels made for suburbans or panels.
I have heard that the bed sides for short beds are close for suburbans but would suspect for your c30 panel, maybe the long bed lower rear section could be used to do the repairs. Good luck and welcome to the forum!!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
10-21-2018, 11:39 AM | #3 |
thanks very much !! I will check out for long bed applications !! )
10-21-2018, 11:43 PM | #4 |
60-66 Nut
Welcome to the forum
A long bed pickup repair panel may or may not be long enough, depending on how far back from the wheel opening you need to repair. If you need to go into the curve going around the back, that will have to be fabricated.
