10-31-2018, 07:25 PM | #1 |
Laminated circuit plug question
I’m getting no juice to the plug wires 1&12 that feed into the laminated circuit and in turn feed the amp meter/ voltmeter can somebody tell me where they originate? Alternator, coil? I don’t know thanks for your help
Posted via Mobile Device |
10-31-2018, 08:20 PM | #2 |
Re: Laminated circuit plug question
The wire from pin #1 originates at the truck's main power distribution point, which is a multi-wire factory splice located inside the wiring harness near the voltage regulator. The wire from pin #12 originates at the junction block on the passenger side fender near the battery.
Both of these wires are protected by 4 Amp inline fuses located near the origination points. The factory fuse holders (if still in place) look like this: |
11-01-2018, 08:45 AM | #3 | |
Proprietor of Dale's Corner
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
11-02-2018, 12:26 AM | #4 |
