Old 05-15-2017, 07:21 PM   #1
trucksforever
Trying to identify gmc suburban
I got this old gmc suburban. I want to know what kind it is. All I know is that it is a 4 wheel drive. There are some numbers in the glove compartment. Does anyone know where I can go to find out what these numbers mean?
trucksforever is offline   Reply With Quote
Old 05-15-2017, 10:01 PM   #2
kwmech
Re: Trying to identify gmc suburban
If you try a little harder, you could be more vague. How about a year, picture, the numbers themselves. The first suburban was in the 1930s something
Old 05-16-2017, 02:55 PM   #3
JoeinT.O.
Look at a "vin decoder" for suburban
JoeinT.O. is offline   Reply With Quote
Old 05-17-2017, 05:56 AM   #4
trucksforever
Looks like something in the 1980's. The guy from the junk yard I got it from thought it was a 1987 gmc suburban. Service Parts Identification#638249 Order#9KR808
Old 05-17-2017, 06:12 AM   #5
trucksforever
The VIN#1GKEV16K8HF516402
Old 05-17-2017, 07:29 AM   #6
Keith Seymore
Keith Seymore's Avatar
Now you've given us something to work with:
1GKEV16K8HF516402
1 = US manufacturer
G = GM
K = GMC nameplate, "multipurpose" vehicle
E=brake system
V= 4wd (formerly "K")
1 = 1/2 ton
6 = Suburban
K=5.7L V8
8=randomized check digit
H = 1987 model year
F = Flint Assembly (Line 1 = pickup; Line 2 = Blazer/Suburban)
516402 = sequential portion of VIN
So: it's a '87 1/2 ton 4wd GMC Suburban with a 350 cubic inch small block Chevy engine, built in Flint, Michigan. We can either tell for certain or guess pretty much everything about that truck except the colors based on that.
https://www.gmheritagecenter.com/doc...t-Suburban.pdf
The label in the glove box is called the "SPID" ("Service Parts ID") label. The codes that populate the label are the "RPO" (Regular Production Option) codes, consisting of the optional content on the vehicle so that you can get the correct parts. You can get more information on them from the link I posted above, or find an "RPO decoder" and type them in individually. The order number is referencing the original order placed by the dealer to get the truck built. The truck is tracked by the order number until it is assigned to the final assembly location and is the truck's "name" until the plant identifiers (PVI and general assembly sequence numbers) are established. It doesn't mean anything to anyone anymore. Once the vehicle leaves the plant the VIN takes precedence.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 05-19-2017, 12:39 AM   #7
trucksforever
Thanks for the help Keith Seymore. I really appreciate it.
1987, gmc, suburban 4x4
