Anti-theft reset
I'm using a 2006 trailblazer ss to build a jeep Wagoneer project. I had to remove the dash to reroute the defrost. Now the anti-theft system pops up on the dash. There's no response from the ignition. No power to the front seats. I've checked all the fuses and relays. Still got nothing. Went to the local Chevy dealer and they won't even touch it because it's not a factory vehicle anymore. Any ideas?
-Josh
1965 Buick Skylark wagon 1968 Jeep Wagoneer 1977 Jeep Cherokee Chief Wide Track 2007 Suzuki M109R |
![]() Join Date: Jan 2007
Re: Anti-theft reset
youtube/internet may be helpful
I recall seeing something about cycling your ignition on/off and leaving it on for 15 minutes or so.... hopefully you can find something. best of luck, Wil
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold ![]() 1972 C10 5.3L/4L60E 12bolt 5Lug - Sold ![]() 1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!! ![]() 1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold ![]() ![]() ![]() 1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold ![]() 1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold) ![]() 2003 K2500HD 8.1/Allison1000/NP263 ![]() |
![]() ![]() Join Date: Jul 2002
I found this
This may work: 1. Turn on the ignition, with the engine OFF. 2. Attempt to start the engine, then release the key to ON (vehicle will not start). look at 'security light', after approximately 10 minutes it should shut off 4. Turn off the ignition, and wait 5 seconds. 5. Repeat steps 1 through 4 two more times for a total of 3 cycles/30 minutes/ The vehicle is now ready to relearn the Passlock Sensor Data Code The vehicle learns the Passlock Sensor Data Code and/or password on the next ignition switch transition from OFF to CRANK. You must turn the ignition OFF before attempting to start the vehicle. 6.Start the engine (the vehicle has now learned the Passlock Sensor Data Code and/or password). Not sure though as I would think some of the body sensors are missing and not giving the anti-theft computer thing a signal.
Bill 1981 GMC High Sierra SWB Stepside Member of Louisiana Classic Truck Club (LCTC) Board Vendors Bill's Gallery Life isn't tied with a bow, but it's still a gift. Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God! It's scary when you start making the same noises as your coffee maker. Last edited by Palf70Step; 10-31-2019 at 08:51 AM. |
