Old 05-17-2011, 01:32 PM   #1
71monteme
71monteme's Avatar
orifice tube
hey guys and gals.
i read some where here to get colder a/c, i could use an orifice tube from a lincoln, i've done the search on the forum and read about 100 posts and could not find the answer.
can some one point me in the right deriction?
thanks
71monteme is offline   Reply With Quote
Old 05-17-2011, 02:54 PM   #2
clinebarger
Re: orifice tube
Chevy uses a Black/White .072" orifice tube.
Ford/Lincoln has used 3 different size orifice tubes over the years.
Blue .067"
Red .062"
Orange .057"
Try the Blue .067" first, Running to small of a orifice can cause high head pressure.
This is used as a band-aid fix for wore out compressors, to much oil, not enough freon.
A GM system thats in good shape & has the proper amount of freon & oil will cool great with the factory .072" orifice.
What year truck are you working on?
clinebarger is offline   Reply With Quote
Old 05-17-2011, 07:45 PM   #3
71monteme
71monteme's Avatar
Re: orifice tube
it is a 97 suburban. a/c works good now but i want it to get down to about 30 degrees. i read that with the lincoln tube i can get it down to 20degrees.
thanks.
thanh
Old 05-17-2011, 08:16 PM   #4
garcia77
Re: orifice tube
70BLAZERX2 posted that a '89 crown victoria would do exactly what you are asking. I dont know how to navigate around here to well but if you look up my old post, there is one in there about A/C issues. might help. I personally havent tried it. Im replacing my hoses this weekend so I might just go for it
garcia77 is offline   Reply With Quote
Old 05-17-2011, 10:40 PM   #5
71monteme
71monteme's Avatar
Re: orifice tube
thanks for the info. and if you do change the tube let me know how well it works.
thanks again.
thanh
Old 05-17-2011, 11:27 PM   #6
clinebarger
Re: orifice tube
thanks.
thanh
The evaporator will freeze over in high humidity at those temps & the low pressure switch will cycle the compressor clutch in & out.
Are you sure its not low on freon? 96-00 vortec compressors are notorious for leaking!!!
Old 05-18-2011, 11:34 AM   #7
71monteme
71monteme's Avatar
Re: orifice tube
thanks for that info. also the a/c is working good, i just wanted colder.
Old 05-18-2011, 04:20 PM   #8
iluvmy72
Re: orifice tube
you will not get to 20!!!!! You'll end up cracking your core
iluvmy72 is offline   Reply With Quote
