Old 01-01-2015, 01:20 PM   #201
SkinnyG
SkinnyG's Avatar
Re: Restoring Rusty
Oh! I didn't know you were cleaning those...
Next time, try Electrolysis.
Suspend the part in a tub of water and 1/4 cup Arm & Hammer washing soda.
Hook the + of a battery charger to some clean scrap iron suspended in the solution.
Hook the - of the battery charger to the part.
Turn on the charger, and walk away.
Come back later and it will be clean, gray, cast iron, ready for header paint.
Quick and dirty video: https://www.youtube.com/watch?v=CqTID6rQ5JA
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 01-01-2015, 03:08 PM   #202
rusty76
rusty76's Avatar
Re: Restoring Rusty
I'm impressed how things clean up with mineral spirits really.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 01-01-2015, 03:20 PM   #203
Gregski
Gregski's Avatar
Re: Restoring Rusty
You know I have tried it in the past and maybe I did something wrong cause although it was working it seemed like it would take years to remove all the rust. Like I said earlier I am not really cleaning the manifolds nor painting them I am going to swap them out for some long tube headers.
Gregski is offline   Reply With Quote
Old 01-01-2015, 03:21 PM   #204
Gregski
Gregski's Avatar
Re: Restoring Rusty
Yes sir, you and me both, took me 20 years to discover this gem, and many $$$ spent on wanna be cleaning products, Simple Green, Purple Power, Orange what ever, seems like anything with a color name in it sucks, LOL
Old 01-01-2015, 03:24 PM   #205
Gregski
Gregski's Avatar
Re: Restoring Rusty - Quick Lighting Fix
frustrated with poor lighting in my garage I finally came up with a quick fix
the problem was that I like to work with the garage door opened, well as you may know when the door is open it cover my florescent light bars so the light don't shine, so solution zip tie a 4 foot light to the hood, done and done
Old 01-01-2015, 03:34 PM   #206
Gregski
Gregski's Avatar
Re: Restoring Rusty - Makes fer a quick clean up.
First of all, who am I to give advice, right?! lol, jk
But in case you don't like oil and grime on your (/your wives) garage floor, here's what works for me
I bought one of these 3 foot wide and 50 foot long rolls of 4 mil plastic that painters use (the 4 mil is pretty thick so I like it, it don't tear like the thin ceran wrap junk)
Anytime I work on the truck I roll out about 4 feet of it and use scissors to cut off a piece, then I slide it under the truck, at 3 foot wide it feels nicely between the wheels even with the car not off the ground, after I am done with the job I just fold it up and stick it in the trash
Old 01-01-2015, 03:42 PM   #207
Gregski
Gregski's Avatar
Re: Restoring Rusty
New Years Day two thousand fifteen, Captains Log day 116
9:00 am 30* inside a cold dark garage...
just a man in his favorite blue jeans and dirty ol' sweatshirt (ok, long johns, three T shirts underneath and two pairs of socks, geez, don't judge me - it's California in the winter)
having degreased the driver side it is time to do the same on the passenger side
Old 01-01-2015, 03:49 PM   #208
Gregski
Gregski's Avatar
Re: Restoring Rusty - Reading Exhaust Manifold Bolts
looking for the Bolt Whisperer?
I know you read spark plugs but I'm not sure if you can read bolts, exhaust manifold bolts for that matter
anyway, if you don't own one of these magnetic chrome trays I strongly recommend one for storing all your loose nuts and bolts during the disassembly process
so from the rear to the front of the cylinder head, the bolts around #8 were black and wet, the bolts around #6 & #4 were semi black and wet, and the last two bolts around #2 were dry, so what, so what does that mean?
my guess oil from the rocker cover gasket area leaking and seeping down and around the exhaust manifold, but that's just a guess
Old 01-01-2015, 03:53 PM   #209
Gregski
Gregski's Avatar
Re: Restoring Rusty - Exhaust Heat Shields
pics of the two heat shields from the passenger side and all four together just because
the one in the upper right hand corner I tried to clean up a bit with Mineral Spirits
Old 01-01-2015, 04:02 PM   #210
Gregski
Gregski's Avatar
Re: Restoring Rusty - What are these for?
can somebody tell me what are these do dads for, other than adding a step in order to remove the exhaust manifold bolts by having to reach for a flat screw driver to bend these tabs back in order to ... wait a minute is that what these are for, to prevent the bolts from wiggling out?!
Old 01-01-2015, 04:05 PM   #211
Gregski
Gregski's Avatar
Re: Restoring Rusty - Passenger Side Exhaust Manifold
and here is what the passenger side (right side) exhaust manifold looks like
again, same as with the other side (driver side) note the pesky air tubes sticking out of the ports
Old 01-01-2015, 04:09 PM   #212
Gregski
Gregski's Avatar
Re: Restoring Rusty - Manifold vs Header
here is the passenger side (right side) manifold compared to the Hedman Hedder, again I don't think this header will fit in my truck, this is just for size/shape comparison
Old 01-01-2015, 04:12 PM   #213
Gregski
Gregski's Avatar
Re: Restoring Rusty - Air Tubes Removed
and removed the air tubes out of this one as well, hope this shows you an extra step to take for those of you guys out there deleting the A.I.R. system by simply removing the outside tubes and plugging the holes with those brass plugs - I believe this will improve exhaust flow and is worth doing
Old 01-01-2015, 04:53 PM   #214
SkinnyG
SkinnyG's Avatar
Yes. A form of "lock washer." Once you get the headers on, you'll wish you had those.
Old 01-02-2015, 05:00 PM   #215
rusty76
rusty76's Avatar
Re: Restoring Rusty
Looking good. So what is your method with the mineral spirits? Do you spray it on? Wipe on or another method. I'm curious. I am impressed how clean it gets things. Keep on keeping man.
My build thread
Crossmembers CC
Old 01-02-2015, 05:30 PM   #216
Gregski
Gregski's Avatar
Re: Restoring Rusty
Simple, a can of Mineral Spirits, roll of paper towels, putty knife or flat screw driver and some small cheap brushes (nylon, brass, steel set), fine steel wool (optional).
Step 1 - use putty knife (plastic or metal) to scrape off big pieces of gunk, dirt, or grime. Use plastic one if you don't want to scratch the paint, use metal if you plan on repainting or if the surface can handle it.
Step 2 - Take paper towel fold it into a 3inch by 3 inch square and soak it with the fluid. Then unfold the towel and fold it just once and start wiping. Get the area wet, the first towel is not so much to wipe things off as it is to get the area wet. THROW DIRTY TOWEL AWAY do not reuse.
Step 3 - Use brushes to loosen hard to get off dirt. You can use a spray paint cap/lid as a cup to poor some fluid in to dip your brush. You can exchange brushes for steel wool as you progress as the area gets cleaner.
Step 4 - Get new paper towel, a dry one and wipe away what will come off. THROW DIRTY TOWEL AWAY do not reuse.
Step 5 - Repeat 2-4
important, start in the worst part, the dirties place or the one most difficult to reach and work out of that zone, also take a break, cleaning sucks, walk away or better yet finish the job the next day or the following weekend
I don't know how the pros do it, but this works for me.
Old 01-02-2015, 05:48 PM   #217
UKNOWME
UKNOWME's Avatar
Re: Restoring Rusty
Kinda like a parts washer, without the parts washer....
2018 Audi S5- wife's ride
1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511
1981 Chevy Silverado- in pieces
1964 Chevy c10
2017 Jeep Wrangler JKU
UKNOWME is offline   Reply With Quote
Old 01-02-2015, 11:45 PM   #218
rusty76
rusty76's Avatar
Re: Restoring Rusty
Thanks. That helps. I've got tons of cleaning in my future.
My build thread
Crossmembers CC
Old 01-03-2015, 01:15 PM   #219
Jake Wade
Jake Wade's Avatar
Re: Restoring Rusty
Thank you, I like it too. I've used KRYLON Rust Tough Enamel - Semi Flat Black on everything from the wheels, to the front bumper and now for bits under the hood. However it is getting too expensive at $7 bucks a rattle can. Thinking about switching to Rust-Oleum.
Would you mind posting the part#?
Jake Wade is offline   Reply With Quote
Old 01-03-2015, 10:48 PM   #220
Gregski
Gregski's Avatar
Re: Restoring Rusty
Dang you like it that much aye? Cool, no problem is this what you are looking for?
FTA 9203
Semi Flat Black
http://www.krylon.com/products/rust-...tative-enamel/
Old 01-03-2015, 10:57 PM   #221
Gregski
Gregski's Avatar
Re: Restoring Rusty - Its Fender Time
got this 20% Off on All Fenders ad in the mail from our local Pick n Pull junk yard so I had no choice but to go pull one
with tax ($4.73), an environmental fee ($4.24), and some BS core charge ($4.99) it came out to be just under $60 bucks, and took me less than an hour to pull it off a green '79 Scottsdale (I was taking my time enjoying a sunny winter day)
Note: not even gonna touch it till summer, I am not painting in the winter ever again
Old 01-04-2015, 12:12 AM   #222
portrodder
Re: Restoring Rusty
Great buy even with all the extra cost they added.
portrodder is offline   Reply With Quote
Old 01-04-2015, 09:11 AM   #223
Jake Wade
Jake Wade's Avatar
Re: Restoring Rusty
FTA 9203
Semi Flat Black
Thank you!
Old 01-04-2015, 04:23 PM   #224
slotard
Re: Restoring Rusty
Nice. I could use a pair in that color, haven't seen one in a yard though.
1973 C20, 350/350
slotard is offline   Reply With Quote
Old 01-04-2015, 05:22 PM   #225
MikeB
MikeB's Avatar
Re: Restoring Rusty
Man, you got that right! Most of that stuff is less effective than dish-washing soap and hot water!
Thank goodness we can still buy Gunk Engine Degreaser. I'll have to try mineral spirits, too.
Mike
1969 C10 LWB -- owned for 34 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 23 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
