Old 10-16-2019, 11:13 AM   #1
Stephen717
Stephen717's Avatar
Wheels
Ok so I know that this topic has been discussed to death but I have the original 16" split rims that came with my 3/4 ton frame and while I kind of like the vintage idea I just don't like the split rims enough to keep them. And the rivets or spot welds or whatever they are inside the rim are hitting my wilwood dual piston calipers up front. So now I'm looking for a correct looking wheel that will fit my truck but not look too big or out of place. My questions are what size wheel do I need to run? how much room do I need between the wheel and the top of the caliper? And how much back spacing would look correct without the wheel looking like it's dished too far one way or the other? As always thanks to everyone on this forum that has helped me with this project so far.
Stephen717 is offline   Reply With Quote
Old 10-17-2019, 08:58 AM   #2
Stephen717
Stephen717's Avatar
Re: Wheels
Anyone?
Old 10-17-2019, 10:47 AM   #3
71gmcC15
71gmcC15's Avatar
Re: Wheels
Not shure of it would clear your brakes but have you tryed stock sqaure body wheels?
( second times the charm) 71 gmc c15 307 sbc 373 rear gears positrac sm 465 trans. ( not listed on spid but is original )
94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless
07 gmc sierra classic rcsb 4.3 lt 5 speed w/t
04 chevy Silverado 1500 ext cab 5.3 4l60e.
81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green)
71gmcC15 is offline   Reply With Quote
Old 10-17-2019, 11:14 AM   #4
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Re: Wheels
I'm running 97 @ord e250 rims. They 16x7.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 10-17-2019, 02:12 PM   #5
Stephen717
Stephen717's Avatar
Re: Wheels
While those look good in not sure if they would clear the calipers. I know that the square body rims won't due to the rivets in the back.
Old 10-17-2019, 02:18 PM   #6
Stephen717
Stephen717's Avatar
Re: Wheels
Here's what I'm talking about
Old 10-17-2019, 03:05 PM   #7
Ol Blue K20
Re: Wheels
My wheels don't have rivets. They're welded. I would get one wheel and test fit it. They were designed for disc brakes. Plenty of clearance on my factory calipers.
Dale
Old 10-17-2019, 10:51 PM   #8
Stephen717
Stephen717's Avatar
Re: Wheels
I will have to try it then, the rivets didn't hit the single piston calipers but for whatever reason they're hitting the wilwood calipers. Knowing that they're welded in the back though is a bit help though as there are a lot of good tires still out there for a 16" rim
Old 10-17-2019, 10:53 PM   #9
Stephen717
Stephen717's Avatar
Re: Wheels
Did you get them off a Ford or from Rock Auto as I can do either. I know there are a few cans around that era and older at the junkyard I frequent but rock Auto has them for $67.79 a wheel.
Thread Tools
Display Modes
