Old 06-10-2018, 09:13 PM   #1
Fred n' Ethel
Fred n' Ethel's Avatar
Question dang AD door adjustment
Hi folks. I searched a bit, no find.
With the AD door shut, how much of the door weight is to be carried by the striker ?
The door is bouncing up and down and banging on the striker. If I slide the striker up as far as it will go to support the latch and keep it from banging, the door then hits at the top at the drip gutter.
Are the door hinges adjusted too high holding the door up too high at the rear edge ?
I live on a rough road and the banging is buggin me.
Thanks.
Fred n' Ethel is offline   Reply With Quote
Old 06-10-2018, 10:18 PM   #2
mongocanfly
mongocanfly's Avatar
Re: dang AD door adjustment
sounds like your door hinges are worn if your door is bouncing up &down
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 06-10-2018, 10:58 PM   #3
MARTINSR
MARTINSR's Avatar
As with any car or truck, you never want the striker to do ANYTHING but hold the door shut with the latch. So the door has to be adjusted so that it fits properly without the striker even in.
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
Old 06-10-2018, 11:16 PM   #4
MiraclePieCo
MiraclePieCo's Avatar
Do you have the rubber bumpers installed? I'd also look at your door seals. They should exert some pressure around the perimeter of the door to cushion it and prevent movement. If the door is bouncing, the bumpers may be missing or the seals not be tight enough.
1951 Chevy Panel Truck
MiraclePieCo is offline   Reply With Quote
Old 06-10-2018, 11:25 PM   #5
Fred n' Ethel
Brian
Maybe the latch is part of the problem.
The striker has a flat bottom "shelf" with a contoured upper surface for the rolling latch to engage. I am going in to the second click but then maybe there is too much clearance from the latch part of the mechanism to the lower shelf. With the door shut completely, it will bounce up and down and bang on the shelf of the striker.
With the door open just a few inches, there is very little movement when forced up and down at the trailing edge.
I'll see if I can lower the rear edge of the door a bit by adjusting the hinges.
Old 06-10-2018, 11:28 PM   #6
Fred n' Ethel
The door seals look new.
What do you mean by the "bumpers" ?
I can adjust the striker in and out to where it latches up perfectly with a gentle slam. But it will still bounce up and down just enough to bang on a rough road.
