Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 10-15-2017, 09:29 AM   #2876
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
[url=https://flic.kr/p/ZnRj3W]20171014_105356
paper dolls and cut outs are over, now just mount the template to my 1/4" plywood and cut out and my spacer plate should be done
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 10-16-2017, 11:22 AM   #2877
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
[url=https://flic.kr/p/Z6L4U9]20171016_111214
SAFETY FIRST
AS usual, off topic
Jim
Old 10-16-2017, 11:27 AM   #2878
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
[url=https://flic.kr/p/CopucJ]20171016_110440[
I want to add a oil filled gauge to the engine compartment for first fire, found an adapter with a 1/8" port
parts s/b here thursday
SAFETY FIRST
AS usual, off topic
Jim
Old 10-18-2017, 06:31 PM   #2879
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
[url=https://flic.kr/p/ZaRiay]20171018_182000
[url=https://flic.kr/p/ZaRkym]20171018_182029
SAFETY FIRST
AS usual, off topic
Jim
Old 11-03-2017, 09:16 AM   #2880
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
[url=https://flic.kr/p/CY6uUs]201711
achieved WOT on first try, but dropped a nut under plenum, still looking
been careful not to lose OEM throttle clip, but I did, now have to source one out
ordered cable adjusters from lokar, so I can install kick down cable
[url=https://flic.kr/p/G8vqQa]20171102_113031
SAFETY FIRST
AS usual, off topic
Jim
Old 11-04-2017, 11:04 AM   #2881
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
found it
[url=https://flic.kr/p/217gR7Z]20171103_103049
SAFETY FIRST
AS usual, off topic
Jim
Old 11-14-2017, 04:51 PM   #2882
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
measure twice, drill once.....NOT
[url=https://flic.kr/p/21rZ1ru]20171114_115711
SAFETY FIRST
AS usual, off topic
Jim
Old 11-15-2017, 12:57 AM   #2883
Chad22873
Chad22873's Avatar
Re: PO has me PO'd
I still enjoy following along with every post Jim. It’s looking good.
Chad22873 is offline   Reply With Quote
Old 11-15-2017, 06:11 PM   #2884
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Thanks Chad for hanging on.
worked on the battery tray today
SAFETY FIRST
AS usual, off topic
Jim
Old 11-15-2017, 06:17 PM   #2885
Chad22873
Chad22873's Avatar
Re: PO has me PO'd
Maybe I will get mine done soon. I keep saying it will be done by Christmas. Its been 2 1/2 years. I dont lack much at this point. Doors and the interior.
BR549
Old 11-15-2017, 10:00 PM   #2886
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
I had good luck with Tri-plus doors, what do you have to do on the interior
SAFETY FIRST
AS usual, off topic
Jim
Old 11-16-2017, 09:33 AM   #2887
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
[url=https://flic.kr/p/GDTo82]20171116_082202
[url=https://flic.kr/p/Zvo8wJ]20171116_082112
Finished up the remote oil filter, aftermarket battery tray was warped when welded, made install a PITA. Keep the thread sealant off the first couple threads
Now I can install larger capacity oil filter
sure going to miss my tool tray, when I install my dual batteries. But, first I have to find and figure out the harness
SAFETY FIRST
AS usual, off topic
Jim
Old 11-18-2017, 11:57 AM   #2888
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Hoses were hitting inner wheel well, had to change in and out for clearance
[url=https://flic.kr/p/21Cxx1X]20171117_094835
SAFETY FIRST
AS usual, off topic
Jim
Old 11-18-2017, 12:06 PM   #2889
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
[url=https://flic.kr/p/ZiWMiz]20171118_110144
SAFETY FIRST
AS usual, off topic
Jim
Old 11-18-2017, 12:07 PM   #2890
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
[url=https://flic.kr/p/21zQpEu]20171117_104736
Now I can re-install oil pan, since fittings are tight, needed clearance to swing the wrenches
SAFETY FIRST
AS usual, off topic
Jim
Old 11-18-2017, 12:54 PM   #2891
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
[url=https://flic.kr/p/DuPmS1]20171117_104633
SAFETY FIRST
AS usual, off topic
Jim
Old 11-20-2017, 11:01 AM   #2892
Chad22873
Chad22873's Avatar
Re: PO has me PO'd
I have everything done in the dash. I still need to install my roll bar, flooring and seats. I am going to line the floor first with FATMAT and then lay rubber flooring in rather than carpet. Once I am done with that, its just a few little things and then I will be ready for a test drive.
BR549
Old 11-20-2017, 08:47 PM   #2893
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
cool, keep us posted on progress, are you going to use an OEM rubber mat?
SAFETY FIRST
AS usual, off topic
Jim
Old 11-29-2017, 11:45 AM   #2894
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
ok, so today I got the bright idea to mount my tins on the cylinder head. Plan to make a bridge off of the perimeter bolts( my vortec heads have center bolts and perimeter bolts) using hexagon stock
After some thought, I came up with trying my repro(GM) scripts. Seems like they will work as well
[url=https://flic.kr/p/21UVpvw]20171129_092226
[url=https://flic.kr/p/21ZW4g6]20171129_102801
SAFETY FIRST
AS usual, off topic
Jim
Old 12-16-2017, 10:11 AM   #2895
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
I found some sheathing that looks like original, and some shrink tubing with the same weave. Only, this stuff melts at a much lower temp. So, don't use a blow torch, when an alcohol lamp will do
[url=https://flic.kr/p/HzPpvr]20171215_093227
SAFETY FIRST
AS usual, off topic
Jim
Old 12-16-2017, 04:58 PM   #2896
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
pin out crank and cam sensor
wire crank sensor function
a) 20ga. Lt. Green sensor power (5-12v)
b) 20ga. Yellow/Black sensor ground
c) 20ga. Blue/ White CKP signal
cam sensor
cavity function
a) sensor ground
b) CMP sensor signal
c) sensor power (5-12 volts)
crank sensor( fast)
a) black
b) red
SAFETY FIRST
AS usual, off topic
Jim
Old 12-19-2017, 08:44 AM   #2897
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
SAFETY FIRST
AS usual, off topic
Jim
Old 12-29-2017, 11:49 PM   #2898
Another 72
Re: PO has me PO'd
Inspiring work Jim!
Rob
"1967 Wanna Be" 1972 K5 Blazer
Another 72 is offline   Reply With Quote
Old 12-30-2017, 01:58 PM   #2899
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
[url=https://flic.kr/p/DnbwAp]20171230_112323
Thanks, but at the moment, it's daunting.....trying to get my computers and cam & crank sensors to talk to one another, I can't find a yellow wire. As Vic says " I hate it, when it goes in one color, and comes out another"
Welcome aboard, this is the best forum around. No BS, just a bunch of Motorheads helping each other out
SAFETY FIRST
AS usual, off topic
Jim
Old 01-12-2018, 12:13 PM   #2900
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
[url=https://flic.kr/p/JogKbk]20180109_100258
[url=https://flic.kr/p/23dX6UW]20180107_100745
[url=https://flic.kr/p/FfBYiU]20180111_124653
If you can read this...please turn me over!!!
SAFETY FIRST
AS usual, off topic
Jim
