Old 10-06-2017, 05:55 PM   #1
nbrfd007
nbrfd007's Avatar
1988 RPO Code 8E1 Fuel additional 3 Gallons
Researching the RPO codes on my 1988 K5 Blazer, one is 8E1-Fuel, "additional 3 gallons." Have no other tank option codes. Does this mean a 28 gallon tank?
Thanks,
nbrfd007 is offline   Reply With Quote
Old 11-04-2017, 12:56 AM   #2
Irish1941
Irish1941's Avatar
Re: 1988 RPO Code 8E1 Fuel additional 3 Gallons
Thanks,
Means left factory with 3 gallons more than usual fuel level put in at the factory.
Think it was a $5-$8 charge. Nothing to do with tank size.
31 gallon is RPO NK7 and I think NL9 is smaller tank.
Irish1941 is offline   Reply With Quote
Old 11-06-2017, 08:37 PM   #3
nbrfd007
nbrfd007's Avatar
Thank you,
Old 11-07-2017, 08:50 AM   #4
Keith Seymore
Keith Seymore's Avatar
Just chiming in to say this is correct.
Extra fuel was added if the vehicle was going to be undergoing more shuffling around than usual, for instance for an export vehicle that would be loaded/unloaded extra times at a railhead.
We also had a few vehicles that we ran out of gas shuttling between repair areas at the assembly plant, but that would not be what this RPO was intended to cover.
I'm surprised that one came up on the generic RPO decoders, since technically that would be an SEO (Specialty Equipment Option), as indicated by the different numeric/alpha/mumeric format.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 11-10-2017, 01:12 AM   #5
Irish1941
Irish1941's Avatar
Had it pop up few times on RPO broadcast over yrs. Mostly gov or export spec trucks that would need more moving around more usual as Keith pointed out.
My current '91 ex-cop truck doesn't have it but my '87 fire dept K30 did.
Loads of mis-info out there...for example these guys...
http://www.astrosafari.com/viewtopic.php?f=9&t=71201
Maybe somebody searching will find this and set their mind at ease.
Old 11-12-2017, 06:53 PM   #6
nbrfd007
nbrfd007's Avatar
Thank you
Old 11-12-2017, 07:12 PM   #7
Keith Seymore
Hate it when that happens...
1979-1986
1986 - 2019
