09-25-2018, 11:40 AM | #1 |
3rd brake light
I live in a college town and I need to make sure the texters see the brake lights. I was thinking of how to add a 3rd brake light. So I was wondering what others have done.
I was looking at this one from Chevs of the 40s, https://www.streetrodhq.com/detail/1...Long_X_12.html Here is the write up, but the picture didn't come through. Led 3rd Brake Light. 30 Led Strip 7-1/2" Long X 1/2" High Item # WASL58SMB LED 3rd Brake Light - Flush Mount. Single unit, 60 LED strip (7-1/2" x 1/2") with aluminum housing. Only 1" of back spacing needed to mount housing. The 1/4" thick acrylic lens allows you to fit light into curved fenders, roll pans and pickup bed corners and form them for that seamless look (the acrylic lenses are not intended to be bent-sand down to make smooth curves). Single intensity 3rd brake light. Weld-in or glass-in studs for mounting are included, as well as quality instructions. Red LEDs shine through red lenses with diffusers. I was thinking of welding it in, either just below or above the rear window. Has anyone had any success with a 3rd brake light? |
09-25-2018, 12:52 PM | #2 |
Re: 3rd brake light
I bought an LED 3rd brake light that mounts in the back window on Ebay but haven't tried it. I wanted something that would show up when I hit the brakes but was a bit on the discrete side due to my build plans.
Can't blame you for wanting more stop light showing, a lot of these drivers now have never seen vehicles without a 3rd brake light or huge stop lights on a regular basis.
09-25-2018, 01:40 PM | #3 |
Re: 3rd brake light
Not sure what year your rig is, assuming an AD. but if its a TF one of the other members is using a ford Ranger 3rd light.
http://67-72chevytrucks.com/vboard/s...713560&page=72 |
09-25-2018, 11:36 PM | #4 |
Re: 3rd brake light
Robert, I installed mine just below the bed line, because I cut the top off. In was also a weld in unit. Here's a couple pics....Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
09-27-2018, 11:18 PM | #5 |
Re: 3rd brake light
Here's what I've used it's on a pedestal that swivels. I screwed the base to the back of the cab centered underneath the rear window
https://static.summitracing.com/glob...9909_hx_ml.jpg
RUBBER DOWN AND HIT THE ROAD!!! 1940 Ford Dlx Coupe 1969 Mach1 |
09-28-2018, 01:48 PM | #6 |
Re: 3rd brake light
I installed a 4' length of red LED strip light under my tailgate / above the rear bumper. You really cant see it while parked but if you are in a car behind me, you can. You can really see it at night when I think it's needed most.
I didn't install it on my truck, (....but may in the future) but on another old car we own, I also installed at strobe controller for the LED strip light. It sends a series of pulses to the light that makes it bling very rapidly for the 1st few seconds you apply the brakes. It is a real attention getter in the dark. It flashes the brake lights way faster than I could do with my foot. Cheap and easy to install. -Steve https://www.amazon.com/Stop-Alert-Fa...+flasher&psc=1
"What's that round short pedal on the floor do?" |
09-28-2018, 03:42 PM | #7 |
Re: 3rd brake light
Thanks guys. I have some planning to do. I'm a long way away from electrical, but if I'm going to put something in permanently, it's time.
Whatever I do, I'm using that strobe! |
09-28-2018, 04:50 PM | #8 |
Re: 3rd brake light
I put a 12" led light just below the tailgate and visible above the bumper. With the 4" lift it is very visible to regular height cars and such. We have an abundance of pot heads and texters here. Maybe even some pot head texters too. The local Sheriff says accidents and DUIs are up especially during the tourist season. FWIW Bicyclists on Oregon 101 seem to have a very high mortality rate. Not sure its law but flashing rear red and white front lights really help to see them. Especially important when they think the road is theirs and ride stupidly.
Light position is on page 4 of attached build thread. Last edited by vintovka; 09-28-2018 at 05:06 PM. |
09-28-2018, 05:55 PM | #9 |
Re: 3rd brake light
I have really studied traffic on many levels. One thing is people DRIVE BY the brake lights on the car in front of them. A plane could crash on the street three cars ahead and they wouldn't see it, ALL they are looking at are the brake lights of the car in front of them.
Thus, personally, I wouldn't put the light down under the tailgate. With the lift as vintovka describes that could make a difference. But I still think up higher is needed. I would put it on the back of the cab or in the rear window or in the top of the tailgate because that is where all other cars third brake light is mounted, that is what they are used to seeing, can't throw them a curveball they aren't going to see it. I changed the switch on my Rambler daily driver so that it's mechanical on the brake pedal (mid sixties Ford) now I only have to move the brake pedal about a quarter inch or less to light the brake lights. I can tap on the brake pedal flashing the brake lights without putting my brakes on. I have found people react to it big time, they back off, they slow down, it's pretty remarkable how good it works. I also put reflectors cut from a late model car in the tail lights, that worked GREAT. Those suckers shine now! Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
09-28-2018, 06:05 PM | #10 |
Re: 3rd brake light
I'm in agreement with everything you said.
I just ordered a Ron Francis universal fit 3rd brake light. http://www.ronfrancis.com/prodinfo.asp?number=TD%2D1R I plan on trying to fit it over the rear window. Luckily I have a sacrificial cab for such "test fits". If it works there, great, if not I'll try it below the rear window. If for any reason I can't get it to fit in either location, then I'm getting the one in the rear window for the truck. Any way I go, I'm getting that flasher unit to "strobe" the brake light for a few seconds prior to going LED red. I'm also going with LED brake and turn lights to help brighten up the rear. The more I can make others LOOK my way, the better. |
09-28-2018, 06:22 PM | #11 | |
Re: 3rd brake light
Brian
09-29-2018, 07:59 AM | #12 |
Re: 3rd brake light
I purchased some round two inch- 2 way LED lights to install recessed into the rolled steel ends of my 51 AD for added protection . What I like about these lights is they turn white when in reverse and also turn Red for brakes. same light but very small. I realize that the later year chevy's 55 plus don't have these rounded bed pocket/ends but if I was going to cut i large light into my cab I would install one that didn't draw your eye there until it was lit. Not sure if that is possible?
How about an older 80's style that mounts up against the rear window inside the cab? All of the cars in late 80's had them - Thats when the National Highway Safety Board came out with their study on 3rd brake lights. I think all passenger vehicles were required to equipped 3rd brake lights around then. I remember there being a visor around the light so the light would not flood the interior of the car. If you put a light tint on the back window it would conceal this 3rd light even more.
current ride 1951 AD Chevy 5 window 2004 LS Gen 3 [/B] 1965 fleetside Sold |
09-29-2018, 08:31 AM | #13 |
Re: 3rd brake light
Having as much rear brake light visible as possible is really important for those who travel on winding roads in coastal areas. 101 can be hazardous due to landslides and frequent stops for road work. I always hit the emergency flashers when stopped and no one is behind me. Tough to go from 60 to zero on a blind turn with little notice.
09-29-2018, 10:50 AM | #14 | |
Re: 3rd brake light
Brian
09-30-2018, 06:18 PM | #15 |
Re: 3rd brake light
4 feet of led strip.
brakes and brake/tail
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
09-30-2018, 06:41 PM | #16 |
Re: 3rd brake light
Lots of light!
8man-aka Robert 1948 on a S10 Frame, small block with a carb 1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL] [/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204 |
10-02-2018, 12:32 AM | #17 |
Re: 3rd brake light
yes, the more the better, people don't see anymore than they want to. I used an LED 3rd brake light as well as LED taillights. they are so bright and look good.
10-02-2018, 06:31 PM | #18 |
Re: 3rd brake light
I still really like what dwcsr did with one of his builds.
http://67-72chevytrucks.com/vboard/s...569491&page=10 Light work starts w/post #240 |
10-03-2018, 10:15 AM | #19 |
Re: 3rd brake light
He did a good job. I got to meet him, but he was gone before I go to learn from him. My loss.
