04-15-2011, 09:05 PM | #1 |
Newtz '68 Burb
So we went ahead and picked this up today! Always wanted one, finally got one!
04-15-2011, 09:15 PM | #2 |
Re: Newtz '68 Burb
Nice burb and congrats! Any plans to make changes? Love the white walls.
Doug '72 GMC K2500 Suburban 4x4 |
04-15-2011, 09:23 PM | #3 |
Re: Newtz '68 Burb
For now leave as is. Except for the interior which needs a lot of clean up. Mostly we will just clean it up and cruise for now. And thanks btw!
04-15-2011, 09:30 PM | #4 |
Re: Newtz '68 Burb
I just dropped this thing in my driveway a couple hours ago. I haven't traced it out yet but there there is a handle below the dash just to the right of the steering wheel that says overdrive. Is this for real? It has the original 292 with the three on the tree. If so, how does this overdrive work with the tranny? Thanks.
04-15-2011, 11:20 PM | #5 |
Junk Yartist
Re: Newtz '68 Burb
When you do trace it out, TAKE PICTURES!!!! There have been after market overdrives available since fifties (maybe earlier?) I know that some 4x4s with the t-18 had an overdrive that bolted on
-Jeremy YOU ONLY FAIL IF YOU STOP TRYING 70 Crew Cab Build Link 70 GMC Suburban 4X4 build thread 95 Yukon Daily Driver Rebuilding an NP205 |
04-16-2011, 12:22 AM | #6 |
Re: Newtz '68 Burb
Right on, I will! I'll take some pics tomorrow.
04-16-2011, 12:47 AM | #7 |
Junk Yartist
Re: Newtz '68 Burb
sorry, dana 18... not t-18... correct me if I am wrong. I am thinking of scouts and willys
04-16-2011, 01:19 AM | #8 |
Re: Newtz '68 Burb
Wow Newt, that's gonna look good in my yard.
C/10 Rene 1966 Short Fleet "The Hag" 1967 CST Short Fleet "Dark Poly" 1971 Short Fleet 1970 Jimmy Custom 2 WD "Golden Ticket" 1972 Blazer 2 WD "Retro Blaze" |
04-16-2011, 01:31 AM | #9 |
Tasty Cakes!
Re: Newtz '68 Burb
Welcome to the club! We need more pics!
I'm a little and a lot Ground beef: A cow with no legs. ---------------- '66 Chevy SWB "Penny" '67 Chevy Big Window SWB- aka "Pearl" '72 Burb- "Betty" "It's not a hearse dammit" '99 Chevy Ext. cab Silverado |
04-16-2011, 10:55 AM | #10 |
Re: Newtz '68 Burb
Yes sir, yes sir!
04-16-2011, 10:57 AM | #11 |
What?
Re: Newtz '68 Burb
Congratulations!
From what I can see in the pic, it looks like it is still pretty solid.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
04-16-2011, 10:58 AM | #12 |
Re: Newtz '68 Burb
04-16-2011, 11:01 AM | #13 |
Re: Newtz '68 Burb
A few more.
04-16-2011, 11:06 AM | #14 |
Re: Newtz '68 Burb
Thanks! It is pretty solid. It has some rust in the normal areas, rockers, kick panels, etc... The body is very straight, except for the one back door, although it has been repainted once, so you never know whats hiding.
04-16-2011, 11:23 AM | #15 |
Re: Newtz '68 Burb
SPID. A po glued carpet to the whole interior. Any good ideas for getting the glue off? It is pretty dried out, maybe just some hot water and a rough sponge or something...
04-16-2011, 12:07 PM | #16 |
Junk Yartist
Re: Newtz '68 Burb
Check hardware stores and carpet stores... they may have a solvent that works. Should be paint safe. You can also try bug and tar remover. that stuff looks too spread out to try elbow grease and scraping.
04-16-2011, 12:09 PM | #17 |
Re: Newtz '68 Burb
i' try a heatgun to try and release the adhesive if thet doesn't work then use a puddy knife, utility knife and elbow grease once the garpet is off use Goop off to get rid of the remaining glue
a wise man once said "There are only two real rules to life... 1 - Don't sweat the small stuff 2 - Everything is small stuff Last edited by 71gmcburb; 04-16-2011 at 12:11 PM. |
04-16-2011, 01:10 PM | #18 |
Re: Newtz '68 Burb
Thanks guys!
04-16-2011, 02:36 PM | #19 |
What?
Re: Newtz '68 Burb
I have good luck using these on various stuck on stuff.
Gum Out carb cleaner, and Goof off bug n' tar remover. I'd start out mild, such as hot water and soap. Then, step it up gradually with various brushes and scotch brite pads. When you decide to go with the harsh stuff, start out on a spot that is out of site. I've also removed dried up glue like that with a fine wire brush on a drill, just go along very lightly so as to not damage the paint. All depends on how dried up it is, crustier the better since it will flake off. If it's still gummy, then you are in for more elbow grease.
04-16-2011, 03:29 PM | #20 |
Re: Newtz '68 Burb
Thanks Vectorit. Ya it's pretty dry. Hopefully it's not too bad.
04-16-2011, 07:13 PM | #21 |
BlahBlahBlah
Re: Newtz '68 Burb
Ive had a 67 with overdrive and I have a 69 right now with overdrive. The 67 handle was chrome and said overdrive across it and the 69 handle is black plastic and it says overdrive on it.
I dont remember for sure but I was thinking the spids on them both said overdrive.
… … … … … … … … ... … … … … … … … … … … … Monroe Swap meet May 18-19. Mike has the same spots for the NW guys he's had forever. Lunch time BBQ at the spaces. If you have stuff to sell bring it along. If you have a question PM stllookn (Mike) here via the board. https://67-72chevytrucks.com/vboard/...d.php?t=851291 |
04-16-2011, 10:33 PM | #22 |
Junk Yartist
Re: Newtz '68 Burb
I really want to see pictures of that OD!
04-16-2011, 10:49 PM | #23 |
Re: Newtz '68 Burb
Newt, I love the photos, if you want some stock hub caps give me a call.
04-16-2011, 11:36 PM | #24 |
TILT COLUMN GURU
Re: Newtz '68 Burb
Very nice Newt. BB plans in the future?
kevs_classics64 64 Impala SS Conv 72 Blazer 2wd 75 Jimmy 2wd 63 Belair wagon 02 Silverado ext cab. DD RIP EL JAY |
04-16-2011, 11:37 PM | #25 |
TILT COLUMN GURU
Re: Newtz '68 Burb
68??
