11-01-2010, 12:22 PM | #1 |
needs more $$$
No Park Lamps when Headlight On
My Blazer is a 70 with a 67 front clip. It didn't come with the back part of the grille or parking lamps, so I've never had front turn signals. Since I bought it I have installed a Painless wiring kit, new headlight switch and now have the complete front grille with parking lamps.
The blinking functions work just fine (turns and hazards), but the parking lights only turn on when the light switch is on park lights and turn off when the headlights come on. I've read this is a function with the 67-68's, but they stay on with 69-72's. Is there something I can do to make the parking lights stay on when the headlights are on?
1970 2wd Blazer |
11-01-2010, 12:42 PM | #2 | |
Re: No Park Lamps when Headlight On
First thing I would do is to verify that power is present at the park lights wire with the headlights on, it's possible you have the wrong light switch, ground fault or wiring error, Is it a single or dual filament bulb? the wiring is different for each.
the diagram is for a 70-72
1965 GMC shortwide big window 1969 Chevy C20 long (for now) 2005 Silverado 2500HD Crew Cab Quote:
11-01-2010, 01:19 PM | #3 |
needs more $$$
Thanks, fixit-p. The bulbs are dual fillaments. With the headlight switch on park, the low fillament lights up, and when they blink, the bright fillament lights up. This leads me to believe the wiring is correct and grounds are fine, but I could be wrong so I'll still check the power when I get home. The signals also work fine with the headlights on.
You said the switch could be wrong...are they different from 67-72?
1970 2wd Blazer |
11-01-2010, 10:40 PM | #4 |
I believe the first year for "full time" parking lights was 68. You MAY have an incorrect switch, but even if you do, there is no need to replace it. The cheapest fix is to connect the parking light wire to the tail light terminal on the switch, or put a jumper across the two terminals.
Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians. |
11-01-2010, 10:41 PM | #5 |
its all about the +6 inches
do the tail lights go out when the headlights are on?
Did you order a harness for 67? |
11-02-2010, 11:41 AM | #6 | ||
needs more $$$
So I checked power at the light, and once the headlights are on, there's no power.
The kit I used was P/N 10206. It says on their website they are 18 Circuts for 1967-1972 Trucks. I don't see one on their website for 67 only, so I don't believe so. Quote:
On the switch, this is where they are located: So, on the pig tail of the light switch, do I simply just shove a wire across from the 927 wire to the 929? Well, first I should probably check to see if there's power at the 927 wire with the headlights on...
1970 2wd Blazer |
11-02-2010, 12:22 PM | #7 | |
The terminal where 927 originates is pre 68 park lights the newer switches didn't have that terminal it's possible that the after-market switches have them so the switch can correctly cover more years you could jump it like raycow suggests or relocate the wire to the terminal next to #929 (dotted line) those 2 terminals (3 & 5) are already bussed together either way works.
11-02-2010, 02:26 PM | #8 | |
needs more $$$
You all are great! Thanks a ton for the help!
1970 2wd Blazer |
11-02-2010, 03:24 PM | #9 |
I bought the same kit... for our 69 and have the same problem, so I'm glad you asked this question!
69 Chevy C10 88 Sierra 02 2500 Suburban And too many S10s to list! |
11-03-2010, 08:39 PM | #10 |
needs more $$$
Thanks everyone for all the help! It's the way I want now...
1970 2wd Blazer |
08-20-2013, 02:07 PM | #11 |
Tagging this one as I have the same harness and had same issue.
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles 72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2) 2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end 2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED) 2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one) Hook em Horns!!! |
11-02-2013, 07:40 PM | #12 |
Man I love this site. Installed my new parking lights on my '67 and they turn off when the headlights come on. Instead of starting to troubleshoot under the hood and dash I search my problem here and found this thread. Saved me hours probably since I suck at electrical issues.
11-03-2013, 01:20 PM | #13 | |
8/24/13 First Classic Truck '67 Short Fleetside, Candy Apple Red! 350ci, Holly 750 double pumper (too much, will change soon), Headers with FlowMaster exhaust, 700R4 tranny. |
01-04-2019, 10:31 AM | #14 |
thanks needed this info
1971 LWB C10 - 5.3/350 1970 SWB C10 - 5.3/4l60 or 6.2/4l80 not sure yet 1964 malibu ss - ls1/4l60 http://67-72chevytrucks.com/vboard/s...d.php?t=382403 |
01-04-2019, 11:24 AM | #15 | |
01-04-2019, 01:27 PM | #16 |
I thought it was normal, got to fix the parking lights on my 68. They go off when the headlights come on
01-04-2019, 10:32 PM | #17 |
Yes probably normal. Was it identified as a problem in this thread that the parking lights don't glow with headlights on?
01-06-2019, 02:11 PM | #18 |
Now I have to fix 2 vehicle’s problems I didn’t realize I had! Lol. Both my trucks do this. I will be jumping pins on the plug!
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO GO!!! |
