Old 01-15-2020, 03:48 PM   #826
HO455
HO455's Avatar
Re: Suburban and panel finds
Trim parts you may need. Theses are not mine!
https://portland.craigslist.org/wsc/...056179375.html
I have all ( or most all, I believe ) aluminum lower exterior body trim parts and 4 door panel covers for the interior. There are 16 pieces of trim and the 4 panels as shown in the picture. There are two valve covers as well included.
1967 Burban the WMB,1991 S(stink)-10 Blazer,1969 GTO, 1970 Javelin, 1952 F3 Ford 4X4, 29 Model A, 72 Firebird. 85 Alfa Romeo
The WMB http://67-72chevytrucks.com/vboard/s...d.php?t=698377
Old 01-15-2020, 08:24 PM   #827
Killer Bee
Killer Bee's Avatar
Originally Posted by hooverfish View Post
1970 Suburban ……… K10 !
Correct some cosmetics and this would be beautiful.
(cant stand the wood lower trim with this great color,
also the wheels/tires but that's just me)
https://bringatrailer.com/listing/19...et-suburban-2/
Originally Posted by Already Gone View Post
I really like it as is and thought the price would be 25k or so but for 14,500 thats a good deal.
Originally Posted by Killer Bee View Post
only 8 bids so far, 5 days to go...
anyone remember that Doctor's wife's sub that went for $40k+ on BAT?
in case y'all are curious, SOLD $44,500 w/30 bids
here's the aforementioned burb sold for $40,750..
https://bringatrailer.com/listing/19...olet-suburban/
and thread;
http://www.67-72chevytrucks.com/vboa...&highlight=BAT
Old 02-12-2020, 04:30 AM   #828
mcmlxix
Collector of Projects
mcmlxix's Avatar
I'm pretty sure this belongs to a member here ….
https://sacramento.craigslist.org/ct...071708659.html
Rich
1972 K5 Blazer CST Click HERE
Old 02-12-2020, 05:46 AM   #829
mcmlxix
mcmlxix's Avatar
Not mine...
https://sandiego.craigslist.org/ssd/...064973457.html
SUPER COOL 1971 SUBURBAN DONE RIGHT NEW PAINT AND INTERIOR.
350 MOTOR AND 350 TRANS IN EXCELLENT RUNNING CONDITION.
RECONSTRUCTED TITLE.
CALL OR TEXT NOW FOR DETAILS TO 858-869-7827 THX
Rich
Old 02-12-2020, 05:48 AM   #830
mcmlxix
mcmlxix's Avatar
not mine:
https://orangecounty.craigslist.org/...072873572.html
This is a three door 1969 Chevy suburban running driving!
Has a 350 and 3 speed trans.
$3,900 Price not negotiable! Thx 🙏
Rich
Old 02-12-2020, 05:50 AM   #831
mcmlxix
mcmlxix's Avatar
not mine:
https://sacramento.craigslist.org/ct...059767186.html
1968 Chevrolet Suburban
Very nice rust free California truck continuously registered since 1968 with original black plates. Currently registered and insured in CA for road use. Clear title.
C10 Factory 4WD 327ci / SM465 4 speed w/ granny Low / NP205 / 3.73 Positrac Rear/ Warn 35 spline front hubs PS, PB, 6” spring lift, front disc brake conversion, D44 Front Axle w/ GM rear. 2” tow hitch.
Original style steel 16.5” wheels with caps and brand new 35” Cooper Discoverer XPP tires. Also comes with a nice set of shiny aluminum wheels the same size – no tires mounted
83k original miles w/ original 327 engine never removed, cast iron block, forged steel crank, engine compartment is original blue color.
Edelbrock 600 Carb, K&N filter. Fully adjustable performance HEI electronic ignition by Davis Unified Igitions. Hedman headers, nice dual exhaust exits in front of rear wheels.
Runs great – takes a few minutes to warm up. The short rod v8 and posi rear is also really nice offroad. 3rd Gear Low will conquer just about anything comfortably at idle. Rarely even need the 4WD
New paint inside and out in 2014. Flat White single stage enamel. Super EZ to repair. Bedliner paint along bottom.
Complete new interior…headliner, seats and foam, seatbelts, carpet, mats, dashboard, visors, nice steering wheel, all new rubber seals in all windows and doors including windshield, privacy tint on all rear windows.
No Entertainment system, or nice HVAC. These 2 last items are going to cost $$
Was to be an offroad adventure vehicle and now it is too nice to use as planned.
Hagerty Classic Car values says its worth $42K in “Like New” condition $36K if “Excellent”
I have seen professional builds of this truck go as high as $115K at auction. Make Offer.
Prefer to avoid the cost to install HVAC and electronics and auction fees.
Email through Craigslist to make arrangements to view.
Rich
Old 02-12-2020, 05:55 AM   #832
mcmlxix
mcmlxix's Avatar
not mine:
https://spokane.craigslist.org/cto/d...072284888.html
Up for sale, a very neat 1969 C20 suburban,
3 door, barn doors in the back..
Very solid, just a little cancer in front and back of the rear tires, the front 2/3 of the truck is awesome solid. Has the plywood floor, but there is NO rot at all there.
4000$ in the engine alone. It’s a screamer, just has the cam broke in, and we got real busy farming last year, amongst other duties..
Powered by a fresh engine, a 377 Chevy,
(a 350 crank and 400 block), bored .040 over, with forged pistons that are compatible with a turbocharger (had a plan)..1.5 roller rockers, edelbrock aluminum heads, rpm
Intake and 750cfm carb. Headers, but exhaust not finished out... Hei ignition,
Comp cams 280 magnum, 12,500 rpm silicone filled harmonic balancer, and she is extremely responsive and snappy..
Other features are as follows:
Power steering and power disc brakes (former owner swapped in ‘72 pickup discs)
Has trailing arms and rear coil springs for great handling compared to leaf springs.
Older two-tone custom restoration, newer carpet. Dash is unmolested
Brand New KYB monomax shocks (pricey, and tight) and struts,
New U-Joints, and carrier bearing installed
A/C cab- not connected.
Tilt column
Electric adjustable seat(not known if factory)
Have a set of new front weatherstripping.
Note! I did somehow put in the wrong rear main seal off of a 400cu in. But I do have the right part now, to be installed. And will consider doing it for you depending on your offer.
She could use some tires, they have some life on them, just a little uneven wear..
Would not be selling this dream boat if we didn’t have to come up with the down pay for a new home. That’s why I’m offering it.
Thanks for looking!!
God bless,
...and scammers will be ignored. Don’t waste your time..
Rich
Old 02-12-2020, 05:58 AM   #833
mcmlxix
mcmlxix's Avatar
not mine:
https://sacramento.craigslist.org/ct...070597444.html
1970 1-2 ton 3 door suburban 402 big block ac original seats roof air no rust ca car
Rich
Old 02-12-2020, 06:20 AM   #834
Killer Bee
Killer Bee's Avatar
Originally Posted by mcmlxix View Post
I like it!!! tasteful slant nose K burb ready to go wheelin
Old 02-14-2020, 06:17 PM   #835
HO455
HO455's Avatar
[QUOTE=mcmlxix;8677033]not mine:
I find this truck scary. The fuel line to nowhere, bypassed heater core, the hose coming from the what should be the PVC on the passenger side, the wire nut on the battery lead, and the bedliner covered rockers. With a 30K asking price! Run Forest RUN!
Old 02-14-2020, 08:19 PM   #836
Beach-Burban
Beach-Burban's Avatar
[quote=HO455;8678504]
not mine:
HO455: But the license plate...of all people, you've got to love the license plate!
Beach-Burban is offline   Reply With Quote
Old Yesterday, 12:51 PM   #837
pwdcougar
pwdcougar's Avatar
not mine:
I painted my 70 4WD Suburban the exact same color combination back in the early 90's complete with the undercoating below the body line. It was an attempt to hide the crappy body work and filler!
Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those"
1969 Mercury Cougar Standard 4 speed
1969 Mercury Cougar XR7 convertible
1970 4WD Chevrolet Suburban
1968 2WD GMC Suburban
1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997)
pwdcougar is offline   Reply With Quote
Old Yesterday, 12:52 PM   #838
pwdcougar
pwdcougar's Avatar
Looks kinda the same!
Paul
Old Today, 03:32 PM   #839
HO455
HO455's Avatar
[quote=Beach-Burban;8678547]
By gosh I didn't even notice that! My heart has warmed to that poor old Burban.
Thanks for the chuckle.
Old Today, 05:55 PM   #840
HO455
HO455's Avatar
69 K Burban $15000. Not mine.
https://portland.craigslist.org/wsc/...074386695.html
1969 Suburban 4x4. Runs and drives well. Very straight body in good shape. Recently gone through motor. Brakes converted to hydro boost. 14 bolt rear end. New plastic fuel tank.
Old Today, 06:01 PM   #841
Killer Bee
Killer Bee's Avatar
after the ragging on that 67, I can hardly wait to hear y'alls thoughts on this
Old Today, 06:04 PM   #842
HO455
HO455's Avatar
Another 69,a panel this time. With more holes in the hood than you can shake a stick at. $4800. Not mine.
https://seattle.craigslist.org/sno/f...075572248.html
1969 suburban panel Delivery truck
Partially restored needs more work please see second picture of what it’s got done
I bought this thinking I would finish it but my circumstances have changed and I’d like to pass it on to someone who will
Copyright ©2000 - 2020, vBulletin Solutions Inc.
