Old 12-12-2011, 01:53 AM   #1
zst85
zst85's Avatar
looking at a new truck
so today i went to look at a 98 chevy ext cab short bed truck well when i went to test drive it i found out the truck seemed to like slip or stutter continuously really bad taking off not as bad on the road but then when i got back i parked the truck was idling at 2000rpm the guy said his mechanic said the throttle position sensor was bad. would that sensor make the tranny feel like it was slipping and make the truck idle that high?
zst85 is offline   Reply With Quote
Old 12-12-2011, 08:01 AM   #2
BigBlocksRule
Re: looking at a new truck
Scrounge a TPS from a similar truck in a bone yard and take it with your for another test drive. If this doesn't fix it, pass until he can get it fixed. Don't buy another man's troubles. Ask the guy that married my ex
BigBlocksRule is offline   Reply With Quote
Old 12-12-2011, 09:36 AM   #3
tommie
97' Tahoe 2dr/2wd
tommie's Avatar
it would have to be very cheap to buy with problems like that...
tommie is offline   Reply With Quote
Old 12-12-2011, 10:13 AM   #4
BIG MAC
Got dropped
BIG MAC's Avatar
Wise words right there!
93 Chevy C1500 Sport
4/6 Drop, Black and Red Int.
00 K1500 ECSB Z71
Stock Daily Driver w/18" Z71 Wheels
BIG MAC is offline   Reply With Quote
Old 12-12-2011, 01:36 PM   #5
zst85
zst85's Avatar
alright thanks guys thats what i was thinking because the guy wanted 6500 and after that i just wanted to see what your thoughts are about it.
Old 12-12-2011, 02:36 PM   #6
tommie
97' Tahoe 2dr/2wd
tommie's Avatar
no way... not for 6500... better be damn near perfect for 6500
seen some of the newer body styles with LS engines for that
Old 12-12-2011, 02:38 PM   #7
mountie
mountie's Avatar
A TPS....... and the stutter might be a bad lock-up in the torque converter.
Also, a poor idle & (vacuum?) sometimes makes you think it is a tranny, but trannys depend on correct RPM & vacuum.
Smell the tranny fluid...sniff for a burned smell. Deduct $2,000 for a burn smell.
mountie is offline   Reply With Quote
Old 12-12-2011, 07:33 PM   #8
YBNORML
YBNORML's Avatar
For $6500 it should be low miles and in perfect shape. That's alot of money for a 13 year old truck.
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
