12-25-2020, 10:13 AM | #76 |
Re: old style locking hubs
Check out those phillips head screws. I think those were made by Rugged Ridge.
How about these? I don't think I'd like this set-up. "Do you remember what you did with that little tool for the hubs when I handed it to you the last time we needed 4wd?"
12-25-2020, 10:22 AM | #77 |
Carpe manana
I thought those Phillips head screws were an odd choice.
12-25-2020, 10:38 AM | #78 |
Proprietor of Dale's Corner
The Phillips screw are bit strange. But, those hubs tha need a tool to work them. They are a lot strange!
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
12-26-2020, 08:11 AM | #79 |
Can you imagine how those 'screws' would get pack with mud? And the slots aren't that deep. You would definitely want to keep a little wire brush tethered to that tool. And that tool? Better know where that is before deciding to hit the slop
I have one set of hubs that are, what I think, early automatic hubs. They are Dualmatic or Selectro. No knob, just a shiny stainless cover. It appears to be just press-fit on. I'll have to dig those out for pictures. I have never attempted to disassemble one
12-26-2020, 10:02 AM | #80 | |
12-26-2020, 12:36 PM | #81 |
Our 1991 Suburban (square body) had mechanical automatic hubs when we got it. They didn't work once up in the mountains so as soon as we got home I had them swapped out for a set of manual Warn hubs. Actually, I still have those factory hubs sitting out in the garage because I intended to keep the Warn hubs if I ever sold it, but when the time came I just said the hell with it. I'm not planning to ever get another half ton 4x4 anyway.
Current/past Chevy/GMC trucks: 1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner |
12-26-2020, 05:33 PM | #82 |
I never had a problem with those GM automatic hubs. It's all about technique. I did switch mine out, too, just because I wanted as heavy duty and simple as possible. I was also pushing their limit with 35/12.50s
12-26-2020, 07:19 PM | #83 | |
If anyone wants those old hubs, they can have them
12-28-2020, 10:58 AM | #84 |
The technique I used was let it spin lazily until you feel them engage. Not nail it until you feel them grenade. Same with the Gov-Loc. I never blew one of those either using the same technique. It's the trade-off for the convenience. I never looked at walking up to my front wheels and turning knobs as a hard thing to do anyway. I'm a manual kind of guy
12-28-2020, 01:53 PM | #85 | |
The last ten years or so we had that Suburban, I almost never unlocked the hubs as the only time we drove it was when the roads were really bad, or else to just go charge the battery and I wanted to lube up the front end anyway. My 89 K1500 front axles are permanently locked together as it is a "ranch" truck. I'm still waiting to see how the electric/gear actuator holds up on the 2016 long term. It has the manual TC lever but still the "thing" between the front axles. It also has the limited slip rear which I really like but I don't know if it is as vulnerable as the old ones? But I drive like the grandpa that I am
12-30-2020, 03:22 PM | #86 | ||
The newer trucks still use the same code number (G80) as they did back then, but I don't know if they are the same anymore? They had a bad reputation too. I replaced a ton of them too. Most of them just threw up the little gears/springs of the governor. Not exactly what you want roaming around in your gear lube and it deactivates it as far as usefullness. I have seen them explode badly enough to crack the whole housing. These were again usually done by people abusing them. Bigger tires or extensive off roading were mostly to blame. Crazy spinning on a concrete boat ramp was the killer of the worst I ever personally took apart. I hope they are ok now a days because I have one in my 20 Colorado.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
12-30-2020, 04:22 PM | #87 | |
We have a deep water bar at the bottom of our turn-around/parking area where it necks into the driveway, so all the runoff doesn't just run down the drive. It is nice to be able to get going again after slowing nearly to a stop when it is a little slippery without having to grab 4wd just to go another hundred feet. Got spoiled with the Jeep because it has a mechanical full time 4wd with no hubs. Just got it back from the shop yesterday after three months. He is slow but I trust him.
12-30-2020, 11:02 PM | #88 | |
All about them K’s
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
12-31-2020, 07:52 PM | #89 | |
01-01-2021, 12:23 PM | #90 | |
Even back in the 80s-90s when those Gov-locs had such a bad rep, the bigger ones were better. I don't really know why? They still had the same stupid little spinning governor bits as the 1/2 ton units.
I've been out of the game so long, I haven't even seen inside of one of the newer ones. The G-80 name is just an option code during manufacturing. It means different things for different years.
01-01-2021, 01:45 PM | #91 | |
There is also the probability that folks who bought a 2500/3500 HD got them for work and didn't hot rod them like the half tons.
