Old 03-29-2011, 02:12 PM   #1
63gmc
1963 GMC 3/4 ton Chiltons book
Does anyone know where I can get a chiltons book or repair book for my 1963 GMC 3/4 ton? Im sure this isn't in the right section and I apologize. I would really like to find a manual or book that tells you how everything was originally and how to put things back how they should be! Thanks
63gmc is offline   Reply With Quote
Old 03-29-2011, 02:16 PM   #2
jbgroby
jbgroby's Avatar
Re: 1963 GMC 3/4 ton Chiltons book
Chiltons does not go back that far, you need the following book (ebay has a ton) as well as most Old truck parts dealers.
http://www.brotherstrucks.com/prodin...number=LFA6066
jbgroby is offline   Reply With Quote
Old 03-29-2011, 02:37 PM   #3
markeb01
Senior Enthusiast
markeb01's Avatar
I'd suggest your best investment would be the 1963 Chevy Truck Shop Manual. Here's a link where you can either buy the book or an electronic copy. It's an invaluable resource on how to rebuild everything from mechanical components to the alignment of body parts, along with how to remove and replace just about everything. A Chilton's manual does not compare.
http://www.classicparts.com/1963-Sho...ctinfo/04-021/
http://www.classicparts.com/1963-66-...info/04-021CD/
Old 03-29-2011, 02:43 PM   #4
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
May I also interject, get the 60-66 factory assembly manual that's available as well. A lot of pictures to guide you through the process.
Old 03-29-2011, 04:18 PM   #5
63gmc
ok, thank you guys!!!!!!!!!!!
