11-20-2017, 06:32 PM | #1 |
1978 K10 rebuild
So my dad bought this truck new off the lot. Its been in 2 different wrecks and been painted 3 times over the years. Originally it was a 1978 K10 Scottsdale and was dark brown. My dad handed it down to me almost 10 years back and I finally got tired of seeing it start to rust away. I slowly started making changes to it until I just said screw it and blew the thing apart to give it some of the attention it deserved. Before I started this last process, I had already changed out the axles for a 14 bolt and a another dana 44 with flat top knuckles and 8 lug to match the rear. I also swapped out the TH350 and 203 for a NV4500 5 speed and 205 tcase. Pictures of where it was before tear down. I was extremely rusted, even though the pictures don't show it.
11-20-2017, 06:36 PM | #2 |
Re: 1978 K10 rebuild
I bought a 6.0 out of a 2009 Silverado and an 86 c10 to steal the cab off of and ditched the original cab that was shot.
11-22-2017, 07:07 AM | #3 |
Those stainless strips must've covered a lot of rust? It looked really nice and will be cool to see what you do with it. Maybe start a thread in the "builds" section?
In pic 2, what wheels and tires have you got there? And what size? Thanks |
11-22-2017, 12:16 PM | #4 | |
The wheels in the 2nd pic are 17x9 procomps. They are like the cheapest ones they sell or close to it. They didn't last long on it as I didn't like the looks. |
11-22-2017, 12:27 PM | #5 |
I stripped the frame and did the POR 15 and painted everything.
11-22-2017, 12:33 PM | #6 |
Motor trans and tcase getting test fitted and the new cab back from sand blasting and with a coat of primer on it. Absolutely no rust on the new cab!! I also picked up a new cowl hood.
11-22-2017, 12:41 PM | #7 |
I also bought new fenders and did some modifying to open up the wheel wells some more to run bigger tires on a smaller lift. Took some material off the front and pie cut the back to push back the opening.
11-22-2017, 12:47 PM | #8 |
Just getting some of the chassis back together and got the new wheels and tires that I'll be running.
11-22-2017, 12:51 PM | #9 |
Getting the base color down on the cab
11-22-2017, 12:54 PM | #10 |
and the clear.
11-22-2017, 12:55 PM | #11 |
Cab is all done.
11-22-2017, 01:01 PM | #12 |
work on the bed.
11-22-2017, 01:02 PM | #13 |
more progress
11-22-2017, 01:04 PM | #14 |
more.....
11-22-2017, 02:00 PM | #15 |
Looks fantastic - did you paint everything in the garage? It looks very clean for just have been painted it - did you hang plastic or how did you keep the paint dust down?
11-22-2017, 03:15 PM | #16 |
I painted the whole truck in my little two car garage. I did every part separate. I should have put plastic down but didn't. I still have a lot of paint dust in places. I just opened my garage door a couple feet and then ran 3-4 fans in the back of the garage to push the air out. I wet the floor down every time as well. This was my first time ever painting a car so it wasn't ever going to be perfect and its not a show truck or anything. I had little orange peel which I've sanded and buffed out pretty easily. That was the part that made me the most nervous was sanding a new paint job and fear of starting over.
11-22-2017, 03:24 PM | #17 |
I forgot to mention I also raptor lined the bottom of the bed, cab and inside the cab where I didn't paint. I also swapped out the column as the old original had seen better days. I also got the motor harness all hooked up and routed through the firewall where I'll hide the PCM under the dash.
11-22-2017, 03:26 PM | #18 |
And here is how it sits in the garage as of today.
11-22-2017, 09:27 PM | #19 |
Formerly- 1972SuperCheyenne
Amazing looking! Keep up the good work!
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
11-23-2017, 04:44 AM | #20 |
Pretty awesome job! Can't wait to see the finished product!
What color blue are you using, & how many coats of clear? FtP
76' GMC K25 Sierra Classic Camper Special: propane powered 350ci/NV4500/205/D44/SRW 14B/4:10/tach,tilt,a/c - daily driver 77' GMC K35 Sierra Grande C/C: 350ci/SM465/205/D60/narrow 14B DRW/4:10 Flatbed 82' Chevrolet K30 C/C: 454ci/SM465/205/D60/narrow 14B DRW/4:56 Flatbed, 6"Rancho, Alcoa's |
11-26-2017, 12:38 AM | #21 |
That's lookin good! I'm following!
-Aaron '15.5 Chevy Duramax LTZ/Z71, LML, CC/SB '77 Chevy K10, 4" lift, 33-12.50, 350/350 '55 Chevy Short Box (In Pieces)MII,4-link,Bagged,383 Stroker,700r4,3.73posi (SOLD) My 55.2 Chevy 3100 Build |
11-26-2017, 07:14 PM | #22 |
Looks good man, nice work. I'd like to repaint my own truck, and I'd have to do it in a similar size garage.
12-01-2017, 11:40 AM | #23 |
Its actually a paint code off a 2014 dodge that the guy at the paint store helped me with. It's got about 4 coats of clear on top of the 3 coats of base.
12-01-2017, 11:44 AM | #24 |
I got the gauge cluster all finished up and test fitted it all. Modified some of the stock parts alone with the LMC brushed aluminum piece. I don't have a finished picture but I sanded and buffed the brushed part more to give it a better finish and to have it match the factory stuff better. I wasn't real happy with the quality of the part when it first showed up.
12-21-2017, 11:50 AM | #25 |
amp back board and speak mounts built.
