12-03-2018, 09:24 PM | #26 | |
Who Changed This?
Re: An insect nearly burned down my 67 stepside.
12-03-2018, 09:53 PM | #27 |
Moderator
700R4 transmissions will leak from the front seal when the cooler circuit is plugged or restricted...also if the cooler bypass valve is jammed with crud....
As far as flushing the convertor...if they did it correctly they would have been able to show you the metallic content from inside the convertor...the system I use has a pleated coffee filter style element that catches the contaminants for easy identification. As an aside, any metal fragments in the filter from the flushing means the convertor MUST be cut open and repaired or replaced. Perhaps they have a similar system... As far as "burnt clutches"...700R4's, even after they have been "beefed up" all suffer from clutch burn ups, band failures, sun shell failures...great for trans shops...not so great for end clients. Anyone looking for a decent auto trans...go straight to a 4L80e...yes you will need a trans controller...but you will have a much stronger drive train...
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox Last edited by AussieinNC; 12-03-2018 at 10:07 PM. |
12-03-2018, 10:43 PM | #28 | ||
Msgt USAF Ret
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
12-03-2018, 10:52 PM | #29 |
Moderator
So they "rebuilt the pump" and didnt replace the pump bushing in the pump housing..aka known as "convertor bearing".....UGH !!!
There are torrington bearings inside the convertor between the stator and impeller...but any metal particles in the flush output should have meant a convertor cut and repair...as I said above... Cant stand shops that work like that... Maybe I am just gettin too old...
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox |
12-03-2018, 11:43 PM | #30 | |
Who Changed This?
12-04-2018, 12:10 AM | #31 | |
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s of OEM identifications and part numbers, all written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
12-04-2018, 08:22 PM | #32 |
well that was a close one! glad it didnt burn , have you figured out if the trans is good or not?
12-04-2018, 08:58 PM | #33 |
I find those buggers EVERYWHERE! On my tractor and both trucks. They make a mess of stuff, but at least they don’t sting, which leads to the other more painful cousin, the Paper Wasp. Dislike them both.
12-04-2018, 09:24 PM | #34 | ||
Msgt USAF Ret
I hate the yellow jackets the most
12-04-2018, 10:26 PM | #35 |
Moderator
Yellow jackets, wasps and even stink bugs all try and invade my work space....
Lil ol can of BrakeKleen works wonders..... Buy the el cheapo brand and you will be good to go...
