01-30-2023, 01:41 PM | #26 | |
Re: Rear roll pan
Could you post a picture up close of the bottom bed corner and the roll pan so we can see what you did up close? Thanks. Beautiful truck!!!
1953 Chevy 3100 - 5 window 1/2 ton pickup My 1953 Chevy Work-In-Process Photo Gallery "I don't have a carbon footprint, I drive everywhere." |
01-30-2023, 05:46 PM | #27 | |
Re: Rear roll pan
Thank you Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
01-30-2023, 05:54 PM | #28 |
Re: Rear roll pan
The near corner of one of youngrodder's pictures looks like a rounded bottom on stake pocket, but I think it is just perspective:
01-30-2023, 06:19 PM | #29 | |
Re: Rear roll pan
It was a nice dream while it lasted.....LOL
01-30-2023, 07:01 PM | #30 |
Re: Rear roll pan
Tough to join stake pocket to roll pan with a curve, I dont see it. might be my aversion to things that will rust out kicking in though.
The roll pan is a large section visually, the stake pocket is left hanging unsupported, maybe just extend it down? |
01-30-2023, 10:56 PM | #31 |
Re: Rear roll pan
I like LG's comment and photoshopped pic add in. it could be added to at the lower edge to make the stake pocket longer so it is roughly as long as the roll pan. extend the slight arc of the pocket so it looks natural there like it was made that way.
01-30-2023, 10:59 PM | #32 |
Re: Rear roll pan
I too like that idea. I just wish my metal work skills were and equal to his Photoshop skills..... LOL I'm not sure I could replicate the double curves on the side of the bed stake piece to allow it to wrap all the way around.
01-31-2023, 01:28 AM | #33 |
Re: Rear roll pan
sooner or later you will see a rusted out bedside you can cut the curved section from for an extension
until then hang a taillight in front of the bottom of the stake pocket and call it done |
01-31-2023, 10:19 AM | #34 |
Re: Rear roll pan
that's good work Tempest 67, nice sheet metal fabrication
RUBBER DOWN AND HIT THE ROAD!!! 1940 Ford Dlx Coupe 1969 Mach1 |
01-31-2023, 12:21 PM | #35 | |
Re: Rear roll pan
01-31-2023, 03:34 PM | #36 |
Re: Rear roll pan
It would not be a horrible job to make extensions for the stake pocket. This test took about 10 minutes:
Next step would be to refine the dimensions and make second prototype. The far side in 2nd picture kinked a bit as I did not get the side bent tangent to the bead edge and the beads are slightly too close to each other. It also needs longer sides welded on to make a finished part. A couple hours would probably turn out passable curved extensions. This was 21 gauge, it would be harder to make this out of 18 for a structural repair. If you are into this sort of thing the tools are not expensive..... I used a cheap bead roller and 1/2" beading die for two parallel beads in a flat sheet(Princess auto, jegs, eastwood etc under $150 on sale) A bench mountable sheet metal brake to bend the sides down, (the cheap sort you use c Clamps to clamp a flat plate down. $50) A shrinker to shrink the flanged edge and give it some curve. ($150 at harbour freight) some kind of welder is also needed |
01-31-2023, 10:04 PM | #37 | |
Re: Rear roll pan
02-02-2023, 11:08 AM | #38 |
Re: Rear roll pan
Smooth!
02-02-2023, 12:49 PM | #39 |
Re: Rear roll pan
very nice, any build pictures?
Why the net? |
02-04-2023, 10:26 AM | #40 |
Re: Rear roll pan
if you have a plan as to what you want, but dont have the metalworking tools to match the plan, you could make a 2 sided form out of MDF with routered in details. then use a light gauge of sheet, for ease of bending. place the oversized sheet into the form and then squeeze the form together in a vice or use threaded rod etc to press the form together. if you were making somethinglike LeeGreens shape the sides could be added after the main form was made as they would be wrinkled in a form due to the amount of shrinking needed. just leave a small overhang out of the sides of the form and then hammer form them around the outside of the wooden form. I seem to remember a video that japhands (make it custom) did using this method to build the floor of a battery box or something like that.
I have made stake pockets before using a U shaped piece of formed sheet, then cut out the corners where it needed to bend along a long curve, made the curve shape required on the side pieces, pushed a piece of wood inside the formed part to help keep the shape and dimension the same, then tacked the central "flap" back along the curved part and tacked it on both sides as i pushed it together against the wooden backer.some tape also helps to keep the parts held tight and square but the part needs to be kept cool as you tack so the tape glue doesn't go gooey and also so the part doesn't warp. they would be different than what you want, likely, as the outside edges were smooth, not with a detail, and the corners were square. where there is a will there is a way to make it happen though. |
02-04-2023, 12:12 PM | #41 |
Re: Rear roll pan
Easiest option is to cut a section from a rusted out stake pocket
for a easy fabricated version I'd probably skip the curve and make it straight. Bend the U shape with a wood block and vice, grind some 1/4" flat stock into beads to weld on. Or just tack on some 1/4 round stock for shape and fill the edges with filler sanded round and only take pictures when it is done. Even 'pros' do stuff like that. next harder would be curved, making u shape out of three pieces of sheet bent and tacked together, then add beads from solid stock as above. if it was curved inwards as I showed above, the beads could probably just be a couple inches long and taper to a point. Third option might be to bend the beads out of 1/2" round stock and weld sheet metal to them. I don't think hammer forming the double beads would be easy, but hammer forming for the 54 and newer stake style that did not have beads would be viable. You could make a die out of a bolt, a form out of a block of wood with a groove and hammer the beads into flat stock then bend the sides. I was able to crudely bead some 1/8" sheet with an air hammer and a shape to pound it into. But most importantly: don't let the Internet talk you into making your project larger than you need it to be. |
02-05-2023, 10:48 AM | #42 |
Re: Rear roll pan
skip, your truck looks awesome. I like the high mount brake light option as well, it blends right in. do you have a tailgate as well or just the netting I have seen in other pics? it reminds me of the netting we used on our firetrucks to haul dirty hose back to station for cleaning.
02-26-2023, 02:31 AM | #43 |
Re: Rear roll pan
My 50
1962 C10 Longbox LS 5.3 4L60E----Sold$$ 2014 Ram 4x4 3500 Laramie Diesel..Momma's truck 2015 Ram 4x4 1500 1997 Boxster. 1972 K10 Custom Deluxe LS 6.0 1950 GMC 3100 S10 & LS swapped Last edited by Rickysnickers; 02-26-2023 at 11:30 AM. |
