11-26-2012, 06:44 PM | #1 |
Early X-mas! 6.0 L96+6L90
I bit the bullet and bought this today. It is out of a 2011 2500 2wd with 19,000 mi. It will be going in my 71 chev swb.
I need to start gathering parts. The place I bought it from didn't know which oil pan I needed, but said to find out and they would get me one at cost. So, first question. What oil pan? I have seen people using an F body pan, ctsv caddy pan, summit pans, etc. My truck has a 4/6 drop with 18/20 wheel combo. What is the best? Thanks in advance for the many questions I will be asking.
1972 3/4T 4x4 Chevrolet (383) 1971 c-10 SWB (400 sb) 1972 4x4 Blazer 1969 SWB 4x4 GMC Projects: 1972 stepside 4x4 http://67-72chevytrucks.com/vboard/s...d.php?t=280132 http://67-72chevytrucks.com/vboard/s...d.php?t=285952 http://67-72chevytrucks.com/vboard/s...d.php?t=553672 http://67-72chevytrucks.com/vboard/s...d.php?t=522704 |
11-26-2012, 07:03 PM | #2 |
Re: Early X-mas! 6.0 L96+6L90
Ctsv for me fit perfect bottom of pan was about 1/4 inch above crossmember. My truck is also 4/6.
Posted via Mobile Device |
11-26-2012, 07:14 PM | #3 | |
Thanks John
11-26-2012, 08:26 PM | #4 |
GM swap pan http://www.summitracing.com/parts/nal-19212593
11-26-2012, 08:36 PM | #5 | |
Thanks for the input! john
11-26-2012, 08:53 PM | #6 | |
The list is not complete. Not sure on AFM (active fuel management) engines though, Does the L96 have AFM? |
11-26-2012, 09:06 PM | #7 |
That's gonna be pretty sweet!
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
11-26-2012, 09:11 PM | #8 |
I used an f-body pan on mine.
11-27-2012, 01:59 AM | #9 |
06-08 pan tried to buy used but the wrecking yards laughed at me paid around 280/300 new heres how it looks in my truck
11-27-2012, 09:16 AM | #10 |
Location: Sunny, Florida, some might call it South Alabama
I am using a 98 corvette pan. Seems to be the only one that doesn't even come close to hanging down below the K member.
Just sold my C10...sad day... Looking for a 1972 Blazer to hopefully fill the hole in my heart. |
11-27-2012, 11:27 PM | #11 |
I'm using ece mounts with electric fans. I don't think it will clear manual fan. When using these mounts with the trans crossmember all my factory holes lined up. Since this is my dd I chose the Holley hooker ls manifolds didn't want to deal with headers even though the thorleys are awesome plus the hookers were cheaper and fit like a glove. Just wanted to share a little info from my recent conversion
11-28-2012, 12:17 AM | #12 | |
John
11-28-2012, 02:41 PM | #13 |
How much was the motor and trans?
11-28-2012, 10:22 PM | #14 |
hope this helps.... Im running the gm muscle car pan it's shallower than the stock truck pans by 1 1/2". I'm guessing the f-body pans are close to the same as the holley pan...
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
11-28-2012, 11:50 PM | #15 |
PM'd ya.
Thanks for the info!
12-01-2012, 12:24 AM | #16 |
Subscribed!! I have been thinking about the same swap. I ran across this build from MAST Motorsports. Some good info.
http://ls1tech.com/forums/conversion...ng-hauler.html
Stepside67 2016 Silverado LTZ Crew Cab 2001 Suburban 2000 Sportside Reg Cab 4.8 (Stolen) 1967 SWB Stepside Project |
01-05-2013, 10:25 AM | #17 |
You can do it!
Best Regards, Leon M. Instagram: @TheDirtyDianah
Bagged | 6.0L LS | T-56 (6-Speed Manual) | Turbo Burnout/Rolling Video: Chevy C10 Stepside 6.0L LSx & 6-Speed Manual |
01-05-2013, 10:28 AM | #18 |
HartRod, can you advise on which dirty dingo mounts you ordered? I'm getting ready to do the same thing, and I see a few different kinds...but it looked like the cut off was 73-87, and everything else was muscle car or other vehicle-specific (miata, 240sx, etc.)
01-05-2013, 10:33 AM | #19 | |
http://dirtydingo.com/store/product_...oducts_id=1372 Any I will probably use the CPP motor stands, unless the factory ones will work.
01-09-2013, 12:18 AM | #20 |
What are you going to be doing for a shifter column since this is a six speed.
01-09-2013, 10:09 AM | #21 |
Paddle shifters!
01-10-2013, 09:54 AM | #22 |
Dude, Im jealous and you suck!
Ok, Im better now, great build and your fast my friend!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
01-10-2013, 02:58 PM | #23 | |
I really wasn't fast on the 4x4. It has been 2 years since I pulled the original motor! I did paint the firewall, radiator support, inner fenderwells, and put on a new brake booster and master cylinder, new steering column and wheel, new wireing harness, and new motor! I hope to get started on the LS swap soon! John
01-11-2013, 07:51 AM | #24 |
Nice shop and builds! I'm looking foward to seeing this ls swap some together.
01-12-2013, 10:59 PM | #25 |
A day late and $1 short...
Could you two, jrdv and Hart_Rod, please get a move on we want to see how this story plays out!
Buck Instagram: C10_ustacould 1963 SWB Fleet Side 528 Desert Beige Milly 1967 SWB Step Side 506 Medium Blue The Old Girl 1968 SWB Fleet Side 503 Light Green Ellie SOLD 1965 SWB Fleet Side 507 Light Blue Prescription Strength SOLD 1971 SWB Fleet Side 521 White Shiro SOLD 1968 SWB Step Side 503 Light Green My Old Farm Truck SOLD |
