11-02-2015, 08:20 PM | #1 |
Led lights
Wanting to see if anyone has run into this, I changed everything to leds on my 68 SB from LMC including a LED flasher. All the lights turn on and hazards flash but the turn signals do not so wanted to ask the experts and see what I am missing.
11-02-2015, 08:41 PM | #2 |
Re: Led lights
Your new flasher could be bad or it could be in the wrong socket .
11-02-2015, 09:38 PM | #3 |
Re: Led lights
I am not an expert, but did you install only one LED flasher. I think you would need one for both the Hazards and Signals?
11-02-2015, 10:44 PM | #4 |
Re: Led lights
I have led's in my 66. I had the same problem. Led's don't pull enough amps to make the flasher work. You can install resistors in line to the turn signal bulbs. Or I installed a hidden standard socket and bulb to make the flasher work.
63 GMC long stepside 66 Chevy short fleetside 71 Chevy Longhorn 68 Chevelle Nomad wagon |
11-04-2015, 01:25 AM | #5 | |
Re: Led lights
Here's the one I found that works best.
Bob 1967 2wd Burb, 350/TH350, 3.73 posi |
11-04-2015, 01:36 AM | #6 |
Re: Led lights
When you can use the correct LED flasher that works, why go to all the trouble to install resistors or hidden standard bulbs. I should mention that the flashers that I use have to be grounded.
11-04-2015, 02:33 AM | #7 | |
Re: Led lights
If it were installed in a parallel leg it would just take out whatever lights are on that leg. Using the appropriate flasher, you bypass adding extra, unnecessary resistance (which adds heat, though, not really an issue with a low-current draw like LED's). |
11-04-2015, 10:07 PM | #8 |
Re: Led lights
I tried 4 different "LED" flashers and none of them would work. Lights would flash once then would just stay on. When you use the resistors you only lose the bulb that that the resistor is wired into. Say you wire them into your front lights and the left resistor goes bad you lose your left front light and the left side won't flash. Right side still works. Or when using the hidden lights like I did if the hidden bulb burns out on the left side all that happens is the left side doesn't flash.
67 Burb do you have the part number for the flasher you used. If I can find one that works I would remove the hidden lights. I have found LED's for my wagon and changing the flasher would be much easier than wiring in extra lights.
11-06-2015, 08:08 AM | #9 |
Re: Led lights
Well I ordered 2 Flashers like 67Burb was using and installed them last night in the truck when I got home from work, the Hazards flashed but the Turn signals are still not working so the fun continues, I have now used 2 different LED flashers so my next stop is to ask a local friend who chases electrical issues for local dealership. I will say when they are all on they look great!
11-06-2015, 05:55 PM | #10 | |
Msgt USAF Ret
Re: Led lights
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
11-06-2015, 09:20 PM | #11 |
Re: Led lights
Sent you a PM.
11-07-2015, 12:05 PM | #12 |
Re: Led lights
No just one way, but this has gotten interesting because I replaced all the truck lights with LEDS from LMC and have a 66 LS Cobra and replaced those bulbs with new from Super Bright LEDS and all new LED flashers and they don't work either so its been pretty funny so far. Then the wife chimes in and said I thought they worked before so why did you change them? I went and got another beer.
11-07-2015, 02:54 PM | #13 | |
Re: Led lights
And make sure to ground that little pigtail sticking out of the flasher.
11-07-2015, 06:53 PM | #14 |
Re: Led lights
Yes ive tried both each way.
11-12-2015, 11:00 PM | #15 |
Re: Led lights
From a diagnostic point I would say one has to wonder what is different between the hazard and turn signal circuit. If the flasher works and the relevant light assemblies work when commanded but none of the components work together when the signal system becomes part of the equation I would start looking there. I'm bored at work and have a new task. Thanks.
Paul
Retired USAF - No rockets, no mortars, no bad guys shooting...No stress!!! My Build Thread: Project 72' Green http://67-72chevytrucks.com/vboard/s...d.php?t=587932 |
11-13-2015, 12:52 AM | #16 |
Re: Led lights
A couple years back, I bought another flasher like the two that were in my Burb to have as a spare. I tried it out just so I'd know it was OK. It didn't work. I returned it and got my money back. After doing some research, I realized that it had come with a polarity-change adapter stuck onto it. If I had pulled that adapter off, it would have worked.
If anyone gets one of these flashers with this adapter stuck on the prongs, pull it off before using it in a NEG.-ground vehicle.
11-13-2015, 09:07 AM | #17 |
Re: Led lights
good info I will check today, I am also going to check and see if everything has a good ground.
11-13-2015, 02:34 PM | #18 |
Re: Led lights
If both flashers worked the hazard 4-ways, then they will both be negative ground. There's gotta be something else going on here.
And, grounding the flashers is essential.
12-21-2016, 09:38 AM | #19 |
Re: Led lights
just read all the posts and I am in the process of installing all LED's in my 69 C10 and want to know where I can get the Flashers from I looked on Ebay but they don't tell me if they will work on my truck. Can any of you help or have the link for me the 2 flashers.
1969 C10 long wheelbase stepside. |
12-21-2016, 10:42 AM | #20 | |
Old member
Re: Led lights
Just type in LED flasher in google and it will pull 1000's of them up. https://www.amazon.com/CEC-Industrie.../dp/B00JXLHE8S I have done my whole truck in LED's. If the flashers don't fix it then you have wiring issues. As stated it's polarity senitive. If you have one wire that is swapped it will cause the issue you are having.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
12-21-2016, 11:58 AM | #21 |
Re: Led lights
Ok thanks mine are all factory wires none have been messed with so hopefully everything works right. mine is a 2 prong and I found a EF32rl on ebay and purchased 2 one for turn signals and one for Hazards. I have a Heavy Duty EF32 electronic in it right now but someone told me that it would not work so I ordered this one http://www.ebay.com/itm/131836856669 which is suppose to be the correct one for my truck.
1969 C10 long wheelbase stepside. Last edited by bigK76; 12-21-2016 at 12:10 PM. Reason: added part that was ordered |
12-21-2016, 12:18 PM | #22 |
Re: Led lights
[URL="http://www.memotronics.com/2-prong-electronic-led-compatible-turn-signal-flasher-relay-ef32rl-round-25-amp/"] maybe this one will load
01-08-2017, 05:57 PM | #23 |
Re: Led lights
I have a similar problem I installed my front and rear LED lights and flashers. When I have the head lights off the brake and turn signals work and are bright. But when I turn the headlights or marker lights on they don't work the turn signals work but the tail lights and front marker lights don't come on. Any help?
01-08-2017, 10:32 PM | #24 |
Re: Led lights
Remove the front marker lights and see if everything else works ok.
01-08-2017, 11:27 PM | #25 |
Re: Led lights
I found the problem the LED tail lights I had were not the proper led I need a BAY15D and I had bought a BA15D. Problem is fixed now.
