Old 11-27-2012, 09:40 PM   #1
Rob69rsss
Suburban body swap questions
I've found a body (shell and doors) to replace my rusted out 82. Am I going to be good lifting at the fire wall and rear, or do I need to support the middle while lifting?
Are there any issues I need to be aware of putting a mid-80's body on an 82 frame?
Rob69rsss is offline   Reply With Quote
Old 11-28-2012, 01:44 PM   #2
csa daddy
csa daddy's Avatar
Re: Suburban body swap questions
Support it in middle should have four supports an the body will fit fine on the older chassis
csa daddy is offline   Reply With Quote
Old 11-28-2012, 04:56 PM   #3
chevak20
I don't understand the reply. I would like to know also. I am about to lift my body off later this winter.
chevak20 is offline   Reply With Quote
Old 11-28-2012, 08:32 PM   #4
I don't understand,either. Four supports would be two in the front (at the firewall) and two at the rear,right? I can't say from experience,but I think that should be enough. If the center of the body needs to bear weight on supports,where and how do you do that w/o damaging?
A later '80s body on an '82 frame is not a problem
