11-27-2012, 09:40 PM | #1 |
Suburban body swap questions
I've found a body (shell and doors) to replace my rusted out 82. Am I going to be good lifting at the fire wall and rear, or do I need to support the middle while lifting?
Are there any issues I need to be aware of putting a mid-80's body on an 82 frame? |
11-28-2012, 01:44 PM | #2 |
Re: Suburban body swap questions
Support it in middle should have four supports an the body will fit fine on the older chassis
Posted via Mobile Device |
11-28-2012, 04:56 PM | #3 |
I don't understand the reply. I would like to know also. I am about to lift my body off later this winter.
11-28-2012, 08:32 PM | #4 |
I don't understand,either. Four supports would be two in the front (at the firewall) and two at the rear,right? I can't say from experience,but I think that should be enough. If the center of the body needs to bear weight on supports,where and how do you do that w/o damaging?
A later '80s body on an '82 frame is not a problem
