03-13-2018, 04:30 PM | #1 |
break peddles peddle question
I know that the brake peddles on this trucks are vary high but mine does not seem to even enguage the brakes until the peddle is about half way down.
I have front cpp discs and rear drums with a captonfab booster bracket. they stop the truck fine but it is a little bit of a pain. I have the correct proportioning valve for a disk drum setup. Will shortening the rod and lowering the peddle help? Or will I just be stepping around the problem? |
03-13-2018, 06:08 PM | #2 |
Re: break peddles peddle question
I'm chasing down brake problems too
If you shorten the pedal won't that just put the effective area out of reach? Have you checked the clearance between the booster and the master? It should be 0.25 - 0.75 mm of clearance, but if there is more it will cause what you are talking about. There also could be air in the setup that is compressing before the fluid moves. Have you tried rebleeding?
Mike 1960 C10 Short Step 235 w/ 3 on the tree 1999 Mazda Miata <- Track Car 2016 Chevrolet Colorado z71 2016 Chevrolet Traverse - Wifes Car 2014 Honda CBR500R <- Also A Dust Collector 2009 Suzuki GSXR600 <- Stolen |
03-13-2018, 06:28 PM | #3 | |
Do you mean clearance from the push rod or between the surfaces that come together when it is bolted together. No I have not tried rebleeding but when I took it to the mechanic to check them out he said they were fine. Maybe it is low on fluid.
I wonder if there is a way test to see when I start to get brake pressure maybe the rod is to short. Quote:
03-13-2018, 09:06 PM | #4 | |
03-13-2018, 09:27 PM | #5 | |
Moderator
03-13-2018, 09:45 PM | #6 |
I believe so. It is a dual cylinder.
03-13-2018, 09:54 PM | #7 |
here is the best photo I have of it.
03-13-2018, 11:16 PM | #8 |
That looks like the corvette style dual pot, it is equal but you have a proportioning valve so you should be fine there.
03-14-2018, 12:25 AM | #9 |
60-66 Nut
Is your booster pushrod in the original hole in the pedal or did you drill a new hole 1" lower?
03-14-2018, 10:38 AM | #10 | |
Never Ending Projects
Buddy did his truck conversion and didn't believe me. Had the same problem of low pedal engagement and being touchy. Finally drilled a hole 1" lower and the brakes were perfect.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
03-14-2018, 10:52 AM | #11 | |
03-14-2018, 11:29 AM | #12 |
I have heard of that but never done it. I should give it a try.
03-14-2018, 03:36 PM | #13 |
Moderator
Brake pedal ratio - https://techtalk.mpbrakes.com/how-to...ng-pedal-ratio
03-14-2018, 03:49 PM | #14 |
Thanks. This is always something I have thought about doing but never got around to.
03-14-2018, 06:01 PM | #15 |
03-14-2018, 09:52 PM | #16 |
Sorry to Hijack the thread, I am using Captinfab's bracket, I did drill a hole for the clutch master but not the booster. I don't think the bracket would fit any lower...
04-02-2018, 04:27 PM | #17 |
So i lowered the hole but have not gotten a chance to drive it yet. But what I was wondering while I was laying on my seat pushing the break peddle down with my hand I heard what sounded like air coming out of where the rod comes out of the booster. But it might just be air being pushed out of the rubber cup that covers where the rod goes into the booster. Is this normal?
04-02-2018, 05:24 PM | #18 |
Moderator
While the truck is running? or off?
04-02-2018, 05:37 PM | #19 |
while running
