05-06-2015, 07:52 PM | #1 |
Where does fuel gauge wire go?
05-06-2015, 08:29 PM | #2 |
Re: Where does fuel gauge wire go?
The gas gauge wire goes in front of the tank over to the sending unit.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
05-06-2015, 08:55 PM | #3 |
In front down the "tray" down by the rocker up to the fuse box. Jim
05-06-2015, 09:06 PM | #4 |
Old member
x3
05-06-2015, 09:39 PM | #5 |
So I am OK with how the wire is now?
My wire seems to go through the ceiling and down from the rear of the cab.....I may go on and pull the tank again for a closer look anyway. Last edited by In The Ten Ring; 05-06-2015 at 09:51 PM. |
05-06-2015, 09:51 PM | #6 |
The Older Generation
There should be three or four small clips that clip the wire to the top seam of the tank. LockDoc
05-06-2015, 10:13 PM | #7 | |
I was thinking how clipping it to the top of the tank would be a good idea.....where might I find these clips? |
05-06-2015, 10:51 PM | #8 | |
LockDoc
05-06-2015, 11:08 PM | #9 |
I have one clip and then the wire runs behind , down and then along the door seal.
The picture shows how dirty it is back there, damn now I have to clean it
72 Cheyenne SWB C10 (daily driver) (Super fake cause I just love the glovebox emblem) 70 Camaro RS (frame-off in pieces) 70 Camaro RS (daily driver backup) 69 Custom LWB C10 (son now drives) |
05-06-2015, 11:11 PM | #10 | |
If anyone has one or more clips laying around, I'll buy them! |
05-07-2015, 04:24 AM | #11 |
I've never seen them listed in any of the '67-'72 truck parts sites, but this is the same clip here:
http://www.rickscamaros.com/camaro-t...1967-1969.html I needed a couple as well, and had one for an example, these matched exactly. They are sold a few other places as "Camaro Trunk Light Wiring Harness Clips". BTW, they are also used on the power brake booster support bracket (69+) to hold the brake warning light wire, same clip. - Ken |
