04-20-2017, 07:45 AM | #1 |
Long tube headers
Anyone using long tube style headers and if so what brand and did you have any clearance issues with the install....
04-20-2017, 10:30 AM | #2 |
Re: Long tube headers
There are quite a few threads with recommendations for Header brands and part numbers for various fitment on these trucks.
My notes from researching BB headers on this forum: C10 truck headers too low, headers for chevelle are just right ( no rub on a-arm ) clam shell motor mounts need mods to fit these with BBC ( use tubular or notch clam-shell mounts ) o Hedman Elites for a Chevelle Part number for the Hedman Elite Chevelle headers is 68198. My engine is a BB chevy o Im running hooker chevelle full length headers #2455. I have a bbc and running POL'S tubular engine and tranny mount. o see pictures of clamshell motormount mods: http://67-72chevytrucks.com/vboard/s...d.php?t=584177 o hooker super comp long tubes are working fine for me. they sit even with the lower frame rail. O Here's the Hedman 69170 BBC headers. I'm running POL aftermarket mounts. summary of part suggestions hedman 68198 chevelle headers hedman 69170 hooker 2455 full length guy with 502ZZ used 69196 heddman's, these are mid length BBC for 67-72 C10 Hth, -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
04-20-2017, 10:36 AM | #3 |
I put the SummitRacing brand ceramic coated long tube headers on the 350 in my C10. I had a small issue with the passenger header touching the motor mount. They also hang below the frame rails a bit, but I haven't seen any long tube headers that don't do that.
Nick 1972 Chevrolet C10 Stepside |
04-20-2017, 11:19 AM | #4 |
I bought Flowtech cermamic coated long tubes for a sbc c10, they were scratch and dent and I scratched and dented them where the already were. #1 tube rubs the motor mount, my factory fuel, return and vent line stuck out of the frame just behind motor mount and 1 of them rubbed there too, and they hang low. Like obvious through the wheel well. But They installed with only removing the spark plugs. Pass from the top down, and I think we did drivers side from bottom up. No leaks, look good.
04-20-2017, 05:09 PM | #5 |
I have headman long tube ceramic headers, fit great, but I will probably be replacing them soon, as they hang below the frame and if I want to drop the additional 2.5" I'm going to need headers that I can tuck up even with the frame rails.
1972 C10 - It might be old, but it's not slow |
04-21-2017, 04:05 AM | #6 |
At the body shop.
Spendy but dougs d310c for sbc
" That didnt make it any newer " " Dont antique the equipment " |
