Old 04-23-2018, 02:35 AM   #1
Puddles
292 exhaust manifold cracked. What to buy?
So I just purchased a 64 c20 a week ago and going through it i found the exhaust manifold is cracked so I'm lookimg at what to replace it with.
Heres my issue.
My current manifold has the heat riser\flapper valve. Im trying to figure out if I can install a manifold without the heatriser\flapper valve without any issues. I'm looking at the cheap ebay replacements. Just need something to make the truck driveable without changing the rest of the exhaust or intake.
Any info would be great.
Puddles is offline   Reply With Quote
Old 04-23-2018, 07:51 AM   #2
raidmagic
raidmagic's Avatar
Re: 292 exhaust manifold cracked. What to buy?
Don't know what the weather is where you are but you can do away with the heat riser you just might experience some cold start issues. Probably nothing more than starting an old truck anyway. If you aren't wanting to change anything then a stock replacement is your best bet.
raidmagic is offline   Reply With Quote
Old 04-23-2018, 08:30 AM   #3
vin63
It's Better With Nitro
vin63's Avatar
Surrey, BC? I think https://www.12bolt.com or http://www.cliffordperformance.net might have what you're looking for especially if you want to upgrade. For the intake, there are heater plates available that use the engine coolant to warm the intake manifold.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 04-23-2018, 11:25 AM   #4
rvrfoot
Heres my issue.
Weld it.
rvrfoot is offline   Reply With Quote
Old 04-23-2018, 01:36 PM   #5
shp4man
shp4man's Avatar
There's a Chinese repro of the exhaust manifold available for the 6 banger engines- check Rockauto.
Use super high temp silicone on the gaskets and tighten the bolts in the right order- it's not a perfect casting.
Everybody has to believe in something. I believe I'll have another beer.
shp4man is offline   Reply With Quote
Old 04-23-2018, 02:47 PM   #6
rvrfoot
Dont get the china cheet. Fix yours.
Old 04-24-2018, 09:19 AM   #7
maydaymike
maydaymike's Avatar
I bought one of the reproduction ones a few years ago, and it mated with my Offy intake and sealed up just fine. Summit racing had the best price at the time, with free shipping.
maydaymike is offline   Reply With Quote
Old 04-24-2018, 08:01 PM   #8
67pete300
Where is Surrey? I have one of those in my garage.
67pete300 is offline   Reply With Quote
