05-28-2007, 09:10 PM | #26 |
The LuvShack Garage
Re: GMC Production Numbers (Survivors List)
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
06-01-2007, 04:13 PM | #27 |
The LuvShack Garage
ttt
06-01-2007, 06:39 PM | #28 |
King of Rust
Just registered,, have to wait to get home to confirm and post,, I had no idea that site existed,, good stuff!!
06-01-2007, 06:57 PM | #29 |
It's ok to stare...
OK, I will play even though my Jimmy has a Blazer front end.
Year: 1971 Type: Jimmy Model #: Option sheet painted over Vin # CE114-S11xxx0 Drive Train: 2wd 350/350 had 3.73 posi is now 3.43 posi Options: AC, PB, PS, DW Top |
06-02-2007, 07:29 AM | #30 |
1971 GMC 1500; Model CE15904, VIN# CE134Z120685, 402 eng, 400 Trans, 3.08 rear axle ratio; AM Radio; air conditioning, tinted glass; Power steering and brakes
'71 GMC;fleetside;PB/PS/AC/CC/402 Eng./Custom Paint/110,000act miles/3 fuel tanks(52gal). |
06-02-2007, 05:53 PM | #31 |
King of Rust
Whelp the admin is slow over there so I cant post as I'm in the "que" waiting. Ugggg.
06-04-2007, 05:50 PM | #32 |
The LuvShack Garage
Thanks guys, keep them coming
Here is what we need from everyone willing to help, * Year (Actual year is in vin, production date a real plus) * Type (Sierre Grande / Custom / Jimmy / Etc...........) * Model # (1st set of #'s on glovebox sheet in options section) * Vin # (Also on glovebox, door pillar areas, front of frame) * Drive Train (2 or 4wd is in the vin, info like engine, trans & axle ratios) * Options (A/C, PS, PB, weird stuff, etc......................) This info can be PM'd to me if you feel more comfortable with doing that
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T Last edited by LUV2XCLR8; 06-04-2007 at 06:18 PM. |
06-05-2007, 01:49 AM | #33 |
here are the two canadian built trucks i have sent for the spec sheet on
1972 gmc cab & chassis (2WD CUSTOM 3500) TCE33215xxx44 MODEL CE6003 350/4spd built in oshawa on june 7/72 paint code 505-glenwood green dual rear wheels,18" tires heavy front springs production(in canada only)= 455 1968 suburban gmc (920 4WD) K9E268110XXX1 MODEL K9E20916 307/4SPD built on november 17/67 (OSHAWA paint code fc436a-special order center and rear seat,heavy duty front axle,4spd manual wide ratio,custom comfort &appearance equipment production (IN CANADA ONLY)= 4 Last edited by longhorn71; 06-05-2007 at 01:53 AM. |
06-09-2007, 06:51 AM | #35 | |
The LuvShack Garage
06-09-2007, 12:27 PM | #36 |
Call it whatever you want ----paranoia. After being a victim of a major identity theft, I get a little leary when personal info gets posted on the internet. Whatever it may be----nothing against what you are trying to do, just my quirk for the moment
06-10-2007, 04:08 AM | #38 |
CE20DZA12XX2 ; Info is in sig.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent. |
06-14-2007, 12:55 AM | #40 |
I have to re-verify the Vin. Hope this helps.
Here is what we need from everyone willing to help, * Year (Actual year is in vin, production date a real plus) 1970 * Type (Sierre Grande / Custom / Jimmy / Etc...........) Sierra Grande, Custom Camper, Longhorn, 3/4 ton, 402 B/B w/turbo hydromatic 400 * Model # (1st set of #'s on glovebox sheet in options section)CF234-ZZ * Vin # (Also on glovebox, door pillar areas, front of frame)CF234-ZZ64287 * Drive Train (2 or 4wd is in the vin, info like engine, trans & axle ratios) 2 wheel drive, 133 WHEEL BASE * Options (A/C, PS, PB, weird stuff, etc......................) B93 Door Edge Guards F51 FRT & Rear Shoke ABS F60 H D FRONT SPRING J70 BRAKE BOOSTER EQUIP M49 TURBO HYDRO-MATIC N40 POWER STEERING T60 HEAVY DUTY BATTERY U63 RADIO-PUSH BUTTON Z53 AMP-OIL-TEMP GAUGE Z84 CUSTOM SPORT TRUCK 631 OLIVE VINYL CUST TRM A11 TINTED GLASS C60 AIR COND-ALL WEATHER F59 FRONT STABILIZER EQ G60 AUXILIARY SPRING EQ L47 400 CU. IN. V-8 ENG N33 TILT STEERING WHEEL PO3 CHROMED HUBCAPS UY1 CAMPER WIRING Z17 SIERRA GRANDE TRUCK Z81 CAMPER NAMEPLATE 557 MED OLIVE & DK OLIVE
Billy 1970 GMC Sierra Grande 402/TH400 (Longhorn)14 years and counting rebuild! 1975 (Build) Chevrolet SWB 4X4 350 SB Lifted 6 inches 1970 Ford F250 Ranger 390 BB 2010 Ford Super Duty F250 XLT W/4 inch lift kit and Pro Comp Tires Hub Cap Freak! I need another truck like I need another hole in the head! I'M IN THE MARKET...AS IT WERE! |
06-14-2007, 06:29 PM | #41 |
The LuvShack Garage
Thanks to those who have responded to date
02-10-2014, 08:02 AM | #42 |
got my hands on a TRUE SURVIVOR !!
1967 GMC 1/2 ton 2wd - fenderside (long narrow stepside) --ill get the VIN number and other info posted later! shes a beauty, original California truck, little to know rust. previous owner drove it to Arkansas from California and slapped a "for sale" sign in the window to make his first months rent. i gave it a good home!!! (again for a steal) found this forum while searching for production numbers, (forgot about the fire). i have however heard that most GMCs were produced almost evenly with their Chevy cousins, by make, model and options.. in 1967, Chevy put out less than 20,000 of the long narrow stepsides like my GMC. and i havent seen too many of them on the road these days (chevy or gmc)!! shes parked next to my 67 Chevy 3/4 ton long bed 2wd. |
11-08-2014, 12:29 AM | #43 |
Good luck..!
11-10-2014, 04:57 PM | #44 |
Florida Edition
Too bad this thread is 7 years old.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
11-10-2014, 05:59 PM | #45 |
The LuvShack Garage
People quit trying to help us build the list, oh well.
11-11-2014, 11:48 AM | #46 |
Ha man that sucks.. Could of been useful
02-20-2018, 01:49 AM | #47 |
Year 1970, Custom K1500, 350 sb V8, TH350 1/2 ton 4x4
20gal tank behind seat. Model # KE15934 VIN KE134-ZZ61645 Axel ratios 3.08's, trans ratio unknown, 127 inch wheel base Optons E81 PICK-UP BOX FLOOR {WOOD} F60 H D FRONT SPRING J70 BREAK BOOSTER EQUIP, M49 TURBO HYDRA-MATIC U63 RADIO-PUSH BUTTON V46 CHROME BUMPER-FRONT Z53 AMMETER-OIL GUAGE 606 BLUE VINYL TRIM BX2 B SIDE "MLDG?"-WIDE LWR F51 FRT & REAR SHOCK ABS G80 REAR POSITRAC AXEL LS9 350 CU IN V-8 ENGINE N40 POWER STEERING V43 REAR STEP BUMPER EQ Z52 FULL FOAM SEAT 501 MED BLUE Bought for $200 two months ago in running and driving shape need some TLC but i'm getting it done. One owner unmolested all original a few small dents here and thare and very little cancer in the door jams and fender bottoms. wonderful truck ill never regret buying it. |
06-16-2018, 09:09 AM | #48 |
Ttt
1977 Chevrolet K10 SWB Project 350/4spd/np205 1977 Chevrolet K20 LWB 350/350/203 1991 4Runner 22RE 5 SPD Yanmar Tractor 3 Cyl Diesel |
01-09-2019, 07:32 PM | #49 |
Just bought my CL find and know it is a Canadian truck with a 1979 350 3ontree & glove box info painted over for whatever reason----
1972 C10 Stepper LWB Vin #TCE1421518296 Does anyone know how I can get a built sheet etc.???? Production ######'s site : http://outintheshop.com/prodnum.html Last edited by 72longstepper; 01-09-2019 at 07:37 PM. |
01-09-2019, 07:55 PM | #50 | |
