12-19-2018, 12:50 AM | #1 |
Starter Dilemma 350 crate /700r4
New 350 crate engine was installed. Think they reused the flexplate and starter. Been having starter problems like either nothing or not engaging. Bought a new starter and same deal. New and old one were for a 168 flexplate as they had the staggered mounting setup. Thinking I might have a 153 plate. Teeth on old starter and plate are a little messed up but not real bad. Question. Would a 168 type starter even work on a 153 tooth plate? Is it worth a try to get a 153 tooth type Straight across) starter. Can't really afford to have the newly rebuilt tranny pulled to replace the plate and don't even know what size it is. Old and broke by the beach here. you can see details in link below.
12-19-2018, 08:14 AM | #2 |
Re: Starter Dilemma 350 crate /700r4
153 tooth flexplate is like an inch smaller in diameter. Wouldn't even be close.
1970 C20 Custom Camper - 350, TH350 1997 GMC Suburban 1994 Acura Integra GSR 1987 Dodge Daytona Shelby Z |
12-19-2018, 09:11 AM | #3 |
my new starter worked for either a 168 or 153.
i want to say it was the Summit Racing brand high torque starter...maybe even mini starter. this is the one https://www.summitracing.com/parts/s...mc?prefilter=1 |
12-19-2018, 12:08 PM | #4 |
Notice that starter has multiple sets of bolt holes for different size starters.
12-19-2018, 01:11 PM | #5 |
Thanks for replies. Getting the idea that i have a 168 flywheel with a 168 starter and a bad flexplate. Another $300 to install a $30 part is making me beyond insane. Neither the "restorer" or the Tranny shop said a word. Heads up
12-19-2018, 06:34 PM | #6 |
Could be a simple as the installer not shimming the starter to properly space the starter gear to the flexplate. Especially since a new motor is involved.
Since sometimes you are getting nothing happening, wouldn't hurt to check/replace your battery cables and ignition switch/wire. Could be the installation of the new motor generated the last bend for one or more cables/wires. |
12-19-2018, 06:53 PM | #7 |
Latest install we tried shims and spacing looks good. Flex plate and old starter have visible damage to gears.
Probably something as simple as the original pot head, brain addled "i'm the greatest mechanic ever" guy who did the work. Blinded by dope and incapable of seeing the damage and disclosing it. Imagine your doctor on pot. Probably would say "hey its legal and i feel like the greatest surgeon ever so i must be - its your fault you died". |
12-20-2018, 07:32 AM | #8 |
I've destroyed the flex plate in my truck. After I rebuilt the top end about 3 years ago, I started noticing the hot start issue. Only 1 place carried a replacement starter in the area, so that's what I used. Forget who made it, but it wasn't a Delco. I had to reshim that thing every 6 months. Last spring it got to the point I couldn't start the truck. Looked into it, bad teeth on the flexplate, cracked starter housing.
Did a bunch of research. #1 - Use the right bolts. These are knurled at the top. Unfortunately, the stock bolts are for a 3/8" (0.375") starter hole, and most replacement starters have a 10mm (0.393") hole, so it doesn't hold it in place as well as it should. #2 - Use the proper torque spec. Want to say it is 38 ft/lb. #3 - Use a starter brace. Not sure how many were installed from the factory, or how many factory ones were thrown away. I installed a new flexplate, AC Delco starter, and starter brace. Spent a while shimming it to get it right. It starts better than ever and the starter is very quiet. I tried to find new bolts, there are some designed for the 10mm holes, but I didn't see ones in the length I needed. I have a 6 gauge ground run directly to the back of the starter where it connects to the brace. This certainly helped a bit. I'm almost surprised they don't make the starter gear out of slightly weaker metal, so they starter wears and not the flex plate. I can get a new starter for <$50 and replace it in an hour or less. A flex plate takes quite a bit longer to replace.
12-20-2018, 08:08 AM | #9 |
Low power to the starter will kill parts all day long. You need good grounds on the motor and lots of time all new paint really limits the ground. Clean all the paint from were your grounds hook up and use star washers on all the connections. I ground the battery right to the head. Then ground the motor to the frame and another ground from the battery to the core support. I also like to run the starter solenoid off a relay. I run a #10 wire off the starter lug to the relay and a #10 back to the solenoid. The trigger the solenoid with the little wire that chevy uses for the starter. This cures the issue of not enough current to get the bendix to fully engage and hold while starting the engine. Stared to do this with the race cars in the 80's and have done it on a lot of other stuff to cure just what yous is doing.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
