12-14-2018, 11:17 PM | #1 |
Lockup TC Problem
I have a overdrive 4 speed automatic with a lockup tc in my truck. I have it wired up with a 4th gear only pressure switch (grounds when in 4th) going to the solenoid and from the other lead on the solenoid going to 12V thru a brake light switch. The way I get lockup in 4th but it disconnects when I hit the brakes. The problem I'm having is the tc seems to be sticking in the lockup mode when stopping and almost kills the engine just before coming to a complete stop. I monitored the 12V and it is being disconnected when I apply the brakes. If I keep it in 3rd lockup never happens and the problem goes away. I disconnected power so it never locks up and no problem. TC solenoid sticking?? Did I overlook anything?
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
12-17-2018, 09:11 AM | #2 |
Re: Lockup TC Problem
Yeah I would venture to guess it is sticking,I was going through the same thing .I had to pull my trans for a front seal leak and while it was out pulled my sillynoid out and bench tested ,it would work off and on not being consistant. May check your ground first
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
12-17-2018, 09:52 AM | #3 |
2 ideas for troubleshooting.
Wire the output of the relay to a light in the cab to be 100% sure when the lockup is getting power. Wire the relay up to a switch so it is easy to engage / disengage. With the switch you should be able to engage / disengage and see if you feel it / notice the RPMs change.
1970 C20 Custom Camper - 350, TH350 1997 GMC Suburban 1994 Acura Integra GSR 1987 Dodge Daytona Shelby Z |
12-17-2018, 02:02 PM | #4 |
I have done all the checks that I can think of. Replaced it yesterday, then had to leave so hopefully I can road test it tonight and see if problem is fixed.
12-24-2018, 12:32 PM | #5 |
Followup - I changed out the lockup solenoid and problem is fixed. Now I'm going to look into a vacuum switch to unlock when pulling up a hill.
12-24-2018, 12:59 PM | #6 |
Cool glad it worked for ya , I got a TCI setup in my 69 and blocked the vacum part off and ran it to a switch on the dash . I only lock it up above 60 mph kinda of a pita but I know when its locked or not. I have the same setup in my 63 but ran it through the brake switch and lockup in 3 or 4 I never know if its locked up or not. Its your preference on how to do it just a little info for ya
