Old 11-29-2008, 07:50 PM   #1
quickchevy
quickchevy's Avatar
Vin Numer Help
The door frame plate says Chevy 00 then under it.C1446A104529 The plate on the kick panel is Trim Blank Paint 555.Then under them. Could not make out the letters.But the number is 115.Then next to it CA blank no number.Thanks for any help.
quickchevy is offline   Reply With Quote
Old 11-29-2008, 08:00 PM   #2
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: Vin Numer Help
VIN C1446A104529
Model Year 1966
Chassis 2 Wheel Drive
Body Style Pickup
Series 1/2-Ton
Assembly Plant Atlanta, GA
Sequential Number 104529
Old 11-29-2008, 08:06 PM   #3
jonzcustomshop
1961 crewcab
Re: Vin Numer Help
115 is for swb truck
1966 Factory Color Codes
Code Description
500 Black
503 Light Green
505 Dark Green
507 Light Blue
508 Dark Blue
510 Turquoise
511 Dark Aqua
514 Red
516 Orange
519 Dark Yellow
521 White
522 Gray
523 Silver
525 Saddle
526 Ivory
Old 11-29-2008, 08:09 PM   #4
jonzcustomshop
1961 crewcab
Re: Vin Numer Help
this is the only reference o CA that I found:
Transmissions
Code Series Description Plant
N N/A 4 Speed Muncie
P N/A 4 Speed Muncie
R N/A 4 Speed Saginaw
W N/A 3, 4 Speed Warner Gear
S N/A 3 Speed Saginaw
M N/A 3 Speed OD Muncie
C N/A Powerglide Cleveland
T N/A Powerglide Toledo
CA N/A 3 Speed Auto Hydramatic
Old 11-29-2008, 08:20 PM   #5
quickchevy
quickchevy's Avatar
Re: Vin Numer Help
Thank you for the help.My paint code number is 555.But i do not see it listed.
Old 11-29-2008, 10:46 PM   #6
factorystock
factorystock's Avatar
Re: Vin Numer Help
The 00 might really be DD,double duty? The Saddle color actually had 2 codes 525 and 555, might have been a tu tone. All sequence numbers will start with 10, so it is the 4,529 truck built at Ga assembly plant that year. The VIN has no powertrain info, this would be on the build sheet or protecto-plate,which usually are missing after the 1st or 2nd owner sells.
factorystock is offline   Reply With Quote
Old 11-29-2008, 11:21 PM   #7
LILRED66
LILRED66's Avatar
Re: Vin Numer Help
Actually the production number starts with 100,000, which still makes it the 4,529th off the production line.
The plate on the driver's kick panel is affectionately known as the GVW Plate. It will show the Maximum GVW Rating of the truck...5,000lbs for 1/2 ton and 7,500lbs for 3/4 ton 2wd trucks.
LILRED66 is offline   Reply With Quote
