Old 06-23-2019, 11:13 PM   #1
domano 68
Rear spring replace need pics
Going to give it a try doing it myself. Will let a pro do the front.
So what's involved? Easy job? Spring compressor needed? Tried to find a good video on you tube but not much luck. Thanks.
1971 C10 127 in wheelbase
Model Number-CS10934
Body Type & Seating-Fleetside 8 ft.
Original Factory Price-$2,854
Shipping Weight-3,605 lbs
Total Production-206,313
domano 68 is offline   Reply With Quote
Old 06-24-2019, 11:07 AM   #2
demian5
demian5's Avatar
Re: Rear spring replace need pics
Coil or leaf?
If coil, just jack up the truck, put the frame on jack-stands high enough so the wheels don't touch the ground when you lower it down to remove the springs.
You may have to unbolt the bottom shock bolts and disconnect from the mount if it cant go low enough to remove the springs.
With the truck on jack-stands and lowered just enough to take load off the springs, remove the upper and lower bolt/nut. Usually the lower one threads into the lower spring retainer while the top one has a nut on top of the frame.
Slowly lower the rear end after unbolting, until the springs are clear of the frame and can be removed. But they usually fall on the ground.
If Leaf, same thing, stands under frame, jack under diff. Lower to take load off, unbolts U bolts from axle/spring, then remove front and rear hanger bolts.
Whatever you do, when you work on the spring make sure its unloaded.
And the front you can do easy. Stands under the frame, jack under the lower control arm, jack up against arm and detach lower ball joint (and sway bar) and slowly lower. Install new spring and position upper pigtail in frame to match the insert, verify lower end of spring is in bottom pocket correctly. hold the spring against the inside of the spring pocket with a pry bar or something long and slowly jack the lower control arm back up to attach the ball joint...
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1964 Impala SS
1959 Austin Healey 100-6 BN6
1979 Glastron Carlson CVX 16 SS
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 06-24-2019, 11:11 AM   #3
bozly
This guy does a great job showing you the work. You will need penetrating oil, impact gun + breaker bar, and likely a few new bolts/hardware. I needed new spring retainers $20 when I just did this on my 1971. This is not a hard job, you got this.
https://www.youtube.com/watch?v=qoX4q4VxpUw&t=504s
bozly is online now   Reply With Quote
Old 06-24-2019, 03:33 PM   #4
typerr
For the rear springs I ended up having the cut the spring retainer bolts both top and bottom with my sawsall after loosening them part way. The exposed threads were rusted after 50 years even on my California truck.
typerr is offline   Reply With Quote
Old 07-02-2019, 03:41 PM   #5
domano 68
Yes coil.
Thanks for the replies. Iíll watch the YouTube link.
So when putting the new springs in, will they need to be compressed or can I drop the axle enough to easily place the new springs in position? Thanks again!
Old 07-02-2019, 09:10 PM   #6
bozly
you can drop it enough to get the new springs in without compressing them. just dont drop it so far you snap the brake lines. use a jack under the rear end to control it.
Old 07-02-2019, 10:59 PM   #7
Steeveedee
Steeveedee's Avatar
The shocks will sometimes limit the suspension travel enough that you may need to remove one end's attach bolt(s) to get the suspension to drop enough.
'70 Chevy 3/4T Longhorn CST 400/400/3.54 Custom Camper
"Orange Acres"
Old 07-05-2019, 09:16 AM   #8
domano 68
In the youtube video above, the guy removes his track bar. I assume he does this since he upgrades to an adjustable track bar. Does the track bar need to be removed to do the spring replace job? Thanks!
Old 07-05-2019, 11:44 AM   #9
typerr
No, I was able to remove and install my new springs and shocks without touching the track bar.
Old 07-05-2019, 02:26 PM   #10
domano 68
Thanks!
Old 07-05-2019, 10:25 PM   #11
wpavlis
The hardest part is removing the old springs. I had to use my grinder and a chisel to get the upper bolt out. Same with the bottom ones. My truck is from South Dakota so no amount of penetrating oil would help. That being said it wasn't difficult, just a bit time consuming. I replaced my u-bolts and bushings while i had everything apart. That did add a bit of time.
wpavlis is offline   Reply With Quote
Copyright ©2000 - 2019, vBulletin Solutions Inc.
