06-01-2019, 10:07 AM | #1 |
seized centrifugal on hei
Put on a new rotor and cap and noticed the centrifugal would not turn , Have to take it apart or any other methods
06-01-2019, 05:45 PM | #2 |
Re: seized centrifugal on hei
May not have to take apart. Spray some WD40 on everything, gently pry around with a screwdriver, see what happens. You may need some new weights and pins though...
Take a picture for us, that will help. Be careful removing the springs. I've dropped them, never found one after dropping... Last edited by 68Gold/white; 06-01-2019 at 07:09 PM. |
06-01-2019, 09:11 PM | #3 |
thanks will post pic sun. I did spray with some w-d40 and letting it sit ,but where do I pry on ?
06-01-2019, 09:55 PM | #4 |
Take the rotor off and check for the pads underneath the weights it gets gummed up and needs cleaning. if it has the factory springs on it, they are pretty stiff let alone the gummed up pads.
06-02-2019, 02:37 AM | #5 |
Every one I've seen frozen up I've had to remove the dizzy and take it completely apart. Usually have to soak the bottom side with carb cleaner while moving it back and forth before it will come apart
06-02-2019, 09:07 AM | #6 |
I took it out and sprayed it and again and again all day it moved very little. I,m suprized it ran so good. When I take the roll pin out on the gear to take the shaft out ,do you reuse it or get a new one,if I need a new roll pin is there a certain one to get as in material ,strength etc.
06-02-2019, 10:41 AM | #7 |
Most kits come with a 'complete build', new springs, pins and weights.
Over time they can become sticky, especially if there were ever a cap issue where condensation could build. When you removed the springs and weights usually a piece of emory cloth will do the trick, or a piece of sandpaper. Scott |
06-02-2019, 10:50 AM | #8 |
Working on HEI's is too much work to save $50. I have a box full of old HEI's and all my vehicles have new ones from Skip White for $50.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
06-02-2019, 12:46 PM | #9 |
06-02-2019, 08:58 PM | #10 |
Well I got it loose but for how long.The springs don,t do nothing, like string I,ll try a rebuild kit. Any suggestions on a kit.
06-02-2019, 09:03 PM | #11 |
06-02-2019, 09:40 PM | #12 |
06-14-2019, 09:10 AM | #13 |
I just went through my HEI last winter clean change this and that and it ran good and still does. I was looking for something from Sumitt and ran across there HEI blueprint dizzy on sale a couple months back for $80.Car fires right up and just runs alot better going to get another one for my truck.
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
