Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 06-07-2019, 12:25 PM   #1
dme922
dme922's Avatar
Can you see the problem with my paint?
Feel free to comment on what problems you see with my truck paint?
dme922 is offline   Reply With Quote
Old 06-07-2019, 01:05 PM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: Can you see the problem with my paint?
Trick question?....looks great from a distance
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 06-07-2019, 01:20 PM   #3
dme922
dme922's Avatar
Take a close look at the paint colors
Old 06-07-2019, 03:22 PM   #4
mongocanfly
Post Whore
When I zoom in it starts blurring up...I cant tell if it's a reflection, or am I seeing thru the copper color?
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 06-07-2019, 07:48 PM   #5
Foot Stomper
Foot Stomper's Avatar
According to my computer screen, it appears to have a color shift....lighter in the front - turning dark near back of cab/front of box.
Please tell us more about what is going on and what your thoughts are. Background? etc?
So when is this "Old enough to know better" supposed to kick in?
My 1959 GMC build thread http://67-72chevytrucks.com/vboard/s...d.php?t=686989
Foot Stomper is offline   Reply With Quote
Old 06-07-2019, 09:43 PM   #6
dme922
dme922's Avatar
The shop i had my truck painted at had to repaint the bed due to issues with the paint. Originally the whole truck looked like the cab and now im dealing with two different shades. They are feeding me a line of bull saying it will fade over time and match the front. This trucks sits in the garage and i also didnt think paints these days fade.
Old 06-07-2019, 09:47 PM   #7
dme922
dme922's Avatar
They also are saying they cant see much difference. This is with the original paint.
Old 06-07-2019, 10:42 PM   #8
mongocanfly
Post Whore
Now that you have before and after pics I can see what your talking about....I was thinking the darker bed was just shaded or reflection
If it was issues with paint related to something they did causing repaint, and the fact it doesn't match, I would say this is on them to make it right...
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 06-08-2019, 01:17 AM   #9
Foot Stomper
You're in a jam alright.. You're also right about paint fade...
It needs a complete paint job, unless they can match one of the two colors which is doable.
Keep your cool, take it back and try to work out your best deal because going elsewhere for a proper fix will likely cost you far more.
Good luck, keep us posted.
Old 06-08-2019, 09:40 AM   #10
grumpyolddog
Hey dme922 what brand of paint is on the truck? Did the same painter paint both? So many things can make the same paint be off a bit like air pressure,temp,and number of coats.
grumpyolddog is offline   Reply With Quote
Old 06-08-2019, 10:19 AM   #11
Grumpy old man
Grumpy old man's Avatar
Spraying candy needs to be done all at the same time , gun air pressure / humidity / temperature . # of coats all change the finished product . it's like when you see guys paint metallic on their truck doors while the doors are laying flat ,When mounted they will be 2 different colors . Tough spot to be in ,Have them respray all of it which probably won't happen , Learn to live with it , And stop telling everyone ,Most will never notice .
I'd add lower chrome mouldings ,That would break up the large panels and attract the eye to the chrome .and look good too !
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 06-08-2019, 04:41 PM   #12
dme922
dme922's Avatar
I have already let them know and they are trying to convince me that it will fade and match the cab. I call bs on that. I have a lot of money in this paint job and its hard to be satisfied with the nonsense i have been through with these people.
Old 06-08-2019, 04:52 PM   #13
dme922
dme922's Avatar
To add a little more to the history of this paint issue it all started with the original bed sides that were in great shape. After i first got it back (three years ago) the bed sides started getting what the b/s called solvent pop. So they said it would buff out. That failed to work. Then they agreed to repaint the bed and it matched great but had the same issue within two weeks. After this they tell me that the bed sides metal was contaminated and the only fix would be new bed sides. Which i also call b/s. Anyhow i bought new bed sides and the paint job looks great but now the mismatch colors. All this being said, these bed sides come pre primered black and if he didnt seal it with the lighter grey sealer as he did the whole truck before would that cause this issue?
Old 06-08-2019, 05:55 PM   #14
mongocanfly
Post Whore
primer color can affect the final paint color...
solvent pop is a issue they created...new bed sides wernt needed I don't think....
copied this...
Solvent popping causes
Solvent pop is caused when too much paint is applied or coats are applied on top of each other too quickly. When this is done, gases from the reducer from the lower portion of the clear, are trying to escape, but they are trapped because of the paint thickness or the coat that was applied on top of it, thus creating the bubbles known as solvent pop.
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 06-11-2019, 09:51 PM   #15
dme922
dme922's Avatar
Well i took my truck to the b/s today and their paint rep looked at it and told me that the bed paint would fade in match the cab within six months. Which i feel is total bs. Then they basically told me i was screwed. Eventhough i have a warranty in writing that clearly states it covers workmanship. Which i would think matching paint would be covered under this warranty but one of the painters was trying to say that the warranty only covers the stuff like peeling and so forth not paint matching. This is unreal.
Old 06-12-2019, 07:50 AM   #16
nsb29
nsb29's Avatar
It sounds like if they can’t dazzle you with their work they’re going to baffle you with their BS, if the paint is going to fade in six months they must’ve really used a quality product, and they think the cab won’t fade at the same rate LMAO. It sounds like all you can do now is hope it screws up again. I have found solvent pop happens when the wrong reduce was used and it happens right away not three years down the road
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent
nsb29 is offline   Reply With Quote
Old 06-12-2019, 09:35 AM   #17
StingRay
StingRay's Avatar
Take it back in 6 months when it doesn't match and tell them to do it again. Solvent pop can not come from the metal. If it was stripped to start with and the surface properly prepped then any solvent pop was from layers applied too soon and not allowed to flash sufficiently. Is this a 3 stage or candy color? If not they could have blended into the door and re cleared it. You'd never see the difference then. More stages or candies can be very difficult to match or blend.
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
Old 06-12-2019, 11:27 AM   #18
nsb29
nsb29's Avatar
My bet is they contaminated the original bed when they stripped it, the second time they didn’t strip it and painted over there mess. you’re probably right they put it over the black bedside because they got the color right this second time.
