06-08-2019, 01:34 PM | #1 |
72 Crate Engine Install 95%
My truck is back on the road and doing fine. I installed a 350/290 engine with thm350. It was suggested and also mentioned in the specs. that this engine's power band was a little higher in the rpm band and might benefit from a higher stall converter. So far it seems fine, but the shifts seems a little bit slow. Almost like it wants me to let off the gas and make it shift. It has an adjustable vacuum modulator. Would an adjustment on that help make the shifts a little sooner and smoother? Transmission was completely rebuilt last year. When adjusting the modulator, which direction increases or decreases the shift?
06-08-2019, 01:48 PM | #2 |
Re: 72 Crate Engine Install 95%
Sounds like you need it to shift earlier.
Turn it clockwise for that. Just go about one turn at a time to test. |
06-08-2019, 01:52 PM | #3 |
I thought it was clockwise, but wasn't sure. Thanks.
06-09-2019, 04:03 AM | #4 |
let us know how it goes as I am doing the same to mine and going to install the 350/290 with th350 , at first with carb for break in and then sniper efi
72 Chev Cheyenne Super SB 4x4 350,4spd,buckets, tilt,tach,am-fm,extreme tow hooks,Canadian Model Production 1 of 52 SOLD 70 Chev CST, 350 auto, PS, PB, AC, tach |
