06-11-2019, 09:30 AM | #1 |
Erratic engine idle 72 350
I installed a new 350/290 crate engine. It starts and runs great, but has one issue. I can't get it to hold the idle at 600. Sitting at a light, it just starts increasing, almost like I am depressing the gas pedal. It will not kick down.
I cleaned the weights on the distributor and disconnected the vacuum advance. But I think the distributor is advancing on it's own. I installed 2 heavy springs with no help. Question. Should I lubricate the area under the weights where they rub? If so, I think I would use a lube intended to use on the rubbing block of points distributors. I run a stock distributor with a Pertronix 1 installed. I had no problem with this distributor on the old engine, and I had no issues with the idle. I cannot find any obvious vacuum leaks, but would one cauth the engine to race like that? I am at a loss for what else to check. |
06-11-2019, 10:16 AM | #2 |
Who Changed This?
Re: Erratic engine idle 72 350
Try a stronger throttle return spring. Also, check the throttle shaft for slop. If it's an Edelbrock, you even have to check the passenger's side of the throttle shaft.
06-11-2019, 10:18 AM | #3 |
I know this is probably a dumb question but did you reconnect the return spring on the carb?
06-11-2019, 10:52 AM | #4 |
Yes the return spring is attached. It is a know good q-jet 7042210. This happens when it is off idle, either while driving or if shifted into neutral. It just slowly increases speed, up to about 2000 rpm. I will have to check, but I think the throttle linkage is resting on the stop, and I think the timing is advancing. At first I thought the advance springs were too loose, allowing it to speed up, and as it sped up the weights would keep it going up. That is why I switched to heavy springs, even though it should run best with something less stiff.
The 72 is supposed to have transmission controlled spark, but I don't think I have all the components. So I disconnected any vacuum advance and plugged the fitting. |
06-11-2019, 11:43 AM | #5 |
Check that the choke lever isn't lose and allowing the fast idle cam to rotate around, and that the fast idle screw isn't adjusted in too far.
Could it be a vacuum leak at your booster and when you are pressing on brake its getting more air? And in reality, its running too rich? Both of those would go together BTW. Just some thoughts.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
06-11-2019, 11:58 AM | #6 |
This doesn't really sound like advance to me, it sounds like a vacuum leak. I think I would plug up everything I can at the carb or intake to see if that makes a difference. If it doesn't, spray carb cleaner around the gasket surfaces to see if it makes a difference. Make sure the choke is coming off, and none of the linkage is binding up.
1970 C20 Custom Camper - 350, TH350 1997 GMC Suburban 1994 Acura Integra GSR 1987 Dodge Daytona Shelby Z |
06-11-2019, 12:43 PM | #7 |
Thanks for the ideas. I am going to look for possible vacuum leak, and also the choke/fast idle.
06-11-2019, 08:01 PM | #8 |
Post Whore
I've seen the brake booster as a source for the vacuum leak with your symptoms. As the diaphragm move the leak comes and goes.
Easy to check the timing is the cause. Put a timing light on the engine and watch it when the RPM changes.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban the WMB,1991 S(stink)-10 Blazer,1969 GTO, 1970 Javelin, 1952 F2 Ford 4X4, 29 Model A, 72 Firebird. 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
06-12-2019, 09:38 AM | #9 |
Who Changed This?
If it's the booster, you could check it by just plugging the vacuum line, if it happens while you aren't moving. I know how much fun it is to stop with no vacuum to the booster.
06-12-2019, 07:17 PM | #10 |
running lean can cause a surge in rpms. Too little fuel or too much air ( vacuum leak)
