Old 06-18-2019, 01:54 PM   #1
richards72chevy
richards72chevy's Avatar
Spline on rear of transmission spinning in park.
I have the transmission in park and noticed that piece is spinning while it's in park.I have the drive shaft disconnected.Is this normal with the drive shaft disconnected?I'm waiting on my drive shaft to be finished at the machine shop.I've tried to Google the answer and only see arguments on other forums about the rear wheels spinning in park when the rear is on jack stands.Transmission is a turbo 350.
richards72chevy is offline   Reply With Quote
Old 06-18-2019, 02:35 PM   #2
kwmech
Re: Spline on rear of transmission spinning in park.
No, it should not turn at all if indeed in the parking mode. It is mechanically locked internally into the rear drum. Disconnect the linkage from the trans and rotate the transmission lever all the way clockwise and see if you hear a click and double check the output shaft. If not, time to pull the pan off and have a look see.
Old 06-18-2019, 02:59 PM   #3
mongocanfly
like kw....parking pawl....or not fully in park
Mongo...aka Greg
2013 GMC Z71..daily driver
Old 07-06-2019, 03:37 PM   #4
richards72chevy
Mistake on my part.My home made linkage wasn't letting it drop into park.Next step is getting a good shift linkage kit from lokar or gennie.Thanks for the response.
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
