Old 11-27-2017, 11:56 AM   #1
gsx_martin
Need help to identify my engine
Need help to identify my engine.
It is a 6-inline and is installed in a 1952 GMC 253-22, but I'm pretty sure it is not the original engine.
I found a number located directly beside the engine oil dip stick. Number is: B228370750 maybe the last digit is a C instead of the 0.
Martin
gsx_martin is offline   Reply With Quote
Old 11-27-2017, 01:09 PM   #2
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: Need help to identify my engine
post a picture of each side and the valve cover
The number comes out to a 1952 228 cubic inch GMC motor
Old 11-27-2017, 03:37 PM   #3
gsx_martin
Thanks.
I had read that there is a 216 installed in the 1952 GMC 253-22. But it seems to be wrong.
Nevertheless I will takesome photos of the engine and will post them tomorrow
Old 11-27-2017, 06:08 PM   #4
dwcsr
Hollister Road Co.
dwcsr's Avatar
216 is chevy motor. GMC had its own truck motor until the early 60's
if it is a 216 then its not original
Old 11-27-2017, 09:22 PM   #5
joedoh
joedoh's Avatar
Originally Posted by gsx_martin View Post
Thanks.
47-5? GMC got 228, 248 or 270 cubic inch engines, never got a 216.
dwcsr is right, the first three numbers tell you the engine displacement of a GMC motor, the leading letter is the main bearing clearance corresponding to a list.
your engine number to me indicates its the original engine, replacement GMC 228 are usually zero'd or X'd out or just plain blank past the displacement.
Old 11-28-2017, 10:29 AM   #6
dwcsr
Hollister Road Co.
dwcsr's Avatar
From what I could find 52 was the last 228, 248 was 53 up and 270 larger trucks
Old 11-28-2017, 12:25 PM   #7
joedoh
joedoh's Avatar
228 was available after 52, 53 and even some 54, 248 was available (and standard) in 3/4 ton trucks from 39-55, 270 was optional for everything but 1/2 ton, 3/4 ton and up.
I just took apart a 49 GMC with a 248
Old 11-28-2017, 01:38 PM   #8
gsx_martin
Hello!
Here are the photos I have taken today.
I guess it is the right, maybe original, engine.
The manual, where I had read the normal engine size for 1952 GMC pick up is 216cui is definately wrong
Martin
Old 11-28-2017, 01:42 PM   #9
gsx_martin
Here the number I found on the engine
Old 11-28-2017, 03:41 PM   #10
dwcsr
Hollister Road Co.
dwcsr's Avatar
Definitely a 1952 GMC 228
The problem with identifying GMC is that they didn't go strictly by year like Chevy did. They used serial numbers not VIN numbers that would fall in a particular year.
B228370750 was 1952 but B228370749 could have been 1951 and register both as 1952's or 1951's depending on what state or country it was registered in.
Old 02-08-2018, 03:55 AM   #11
Harley03joe
I Also Need Help Finding My Engine Number On My 1987 R 10 Silverado 5.7
I Need The Location Of The Number
Thank You For Your Help In This Matter
Harley03joe
1931 Ford Like New And For Sale
2004 Harley Davidson Heritage Classic
1987 Chevy R 10 Silverado
2007 Azera
2011 Cadillac CTS Premium
Harley03joe is offline   Reply With Quote
