02-22-2018, 09:50 PM | #1 |
Adventures in truck hunting.
So today I found a 67 c20 on Craigslist that I really liked. It had some rust, but all in all, it is a pretty solid truck. And my instinct was to go buy it. It has coil springs in the rear. When I started looking really close at the pictures, something looked out of place with the rear axle. Then it hit me, the axle had been swapped to a semi-floating corporate 14 bolt. It looks like someone welded control arm and panhard bar brackets to the 14 bolt rear.
Once I saw that, I decided to pass. Has anyone seen a semi-float 14 bolt swapped into a coil sprung c20?
2012 GMC 2500hd/ 6.0 1972 Chevrolet c20 350/350 1986 Chevrolet Monte Carlo SS/ 6.0 lsx |
02-22-2018, 11:54 PM | #2 |
Re: Adventures in truck hunting.
I could be wrong but I think C20's came with Leaf springs.
Ron
Member #111 68 C-10 Daily Driver 70 4x4 Project 76 Jeep CJ-5 Help Support the Board: http://67-72chevytrucks.com/vboard/payments.php He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors. Thomas Jefferson |
02-23-2018, 08:09 AM | #3 |
my 69 c20 has coils
02-23-2018, 11:11 AM | #4 |
I swapped in a 2002 14 bolt in my 68 C-20.If it was done right it is a great swap.Mine also has coils.
68' with no bells or whistles unless I add'em. |
02-23-2018, 03:10 PM | #5 |
semi floating rearends are not nearly as strong as full floating axles, I would have walked away too
02-23-2018, 03:55 PM | #6 |
I agree with El Dorado. Plus I will add, when I see something I just assume it's indicative of the way the owner did everything else. A prelude to other things you find after you get it home. If you put in the corp14 why not go full floating. I'm missing the boat on that one!
White K20 |
02-23-2018, 05:37 PM | #7 |
Shows how much I Know.
Ron
