Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 12-16-2008, 08:24 PM   #51
Sillyoldman
#16876
Sillyoldman's Avatar
Re: What are you using to heat your garage?
My two Kerosene heaters. Had them on today. They kept it about 55 degrees. I think thats pretty respectable considering it's been in the 20's just on the other side of them garage doors.
Posted via Stationary Device
'71 Custom Deluxe C-20 402.
'67 Buick Special 455.
'49 Plymouth Special Deluxe.
"I love that old car smell"
Some people are like Slinkies... not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs.
Sillyoldman is offline   Reply With Quote
Old 12-16-2008, 08:31 PM   #52
corn
I have a 24X24 two stall garage & have two 220v electric heaters AND a 60,000 BTU propane heater keeping me pretty warm. The propane heater is set at 65 degrees & runs about half the time now that we are having north pole temps. I think you might need a little bit more...
corn is offline   Reply With Quote
Old 12-16-2008, 08:38 PM   #53
lyrikz
PITbut
lyrikz's Avatar
Im close to you, but on the other side in monroe... IT was 13 degrees this morning. ahaha.. Now, is kerosene heaters safe but propane heaters are not safe in enclosed areas?
The propane heater you have, do you have to open the doors when you are in the middle of using it so you dont die from the fumes???
lyrikz is offline   Reply With Quote
Old 12-16-2008, 08:43 PM   #54
463
463's Avatar
Corn : if thats a propane in side your shop i would STRONGLY recommend for your safety (fire protection insurance ) that the propane be removed to the outside of the shop. thanks for your time
Trueman
463 is offline   Reply With Quote
Old 12-16-2008, 08:51 PM   #55
463
463's Avatar
for the shop two 220vac 4800 kw construction heaters will do the trick. 4800kw = apx 16000 btu each. in my 26'x26' 10'wall (walls r20 attic r 40 ) shop i have 3 of these. 2 work and the third is a extra for the faster warm ups at -30 and colder. with the electric heat the chance of a explosion (gas fumes) is all but eliminated. i am getting to old for close calls.
Trueman
Old 12-16-2008, 09:14 PM   #56
Sillyoldman
#16876
The propane heater you have, do you have to open the doors when you are in the middle of using it so you dont die from the fumes???[/QUOTE]
I think that any fuel type heater should be used with some caution. Maybe crack a window to draw in some fresh air. Carbon monoxide poisoning is hardly detectable w/o a monitor.
Old 12-16-2008, 09:27 PM   #57
Painter D
Painter D's Avatar
Originally Posted by BarryB View Post
here's a pic of something similar. I also have a home made thermostat made up. Set it on 65-70 runs about ten minutes until it shuts off, then on and off while I am out there working.
That's what I'm using ,as well
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs)
'63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs)
http://67-72chevytrucks.com/vboard/s...=528853&page=5
Painter D is offline   Reply With Quote
Old 12-16-2008, 09:42 PM   #58
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
Originally Posted by Spray-Bomb View Post
Did you vent it like it says you have to ???
It just seems to me that it would waste a lot of heat to vent it
Yeah, I vented it. I didn't feel like waking up dead.
DirtyLarry is offline   Reply With Quote
Old 12-17-2008, 12:11 AM   #59
corn
No dain brammage so far.
Ive done it this way for @ 10 years now with no problem, but my garage is less than air tight.
Old 12-17-2008, 12:28 AM   #60
corn
Note the cap on that empty tank...
Old 12-17-2008, 03:32 AM   #61
Nolowrider
Nolowrider's Avatar
The sun. It's free and you can count on it everyday.
Nolowrider is offline   Reply With Quote
Old 12-17-2008, 12:29 PM   #62
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
If I had a small area and nat or LP Id use an Infrared, they are ventless and put out around 30,000 btu depending on the number of grates.
I use this 165 btu because its cheaper to run and have 2160 sqft to heat.
Reddy Heater R165DT
Heats up to 3,900 sq. ft.
165,000 Btu/Hr.
13.5-Gallon Tank
Runs Approximately 11 Hours Per Tank
Patented HSI Technology
Fuel Gauge
Built-in Thermostat
Lighted Power Switch
10" Rugged Pneumatic Tires
One-Year Warranty
For Large Construction, Commercial and Industrial
sneakysnake is offline   Reply With Quote
Old 12-17-2008, 01:18 PM   #63
463
463's Avatar
Corn: mty or full no difference.
Trueman
