Old 12-11-2018, 05:56 PM   #1
i_live_in_canada
1990 chevy bucket seats swap
i have a 1990 chevy with the bench seat in it, my brother in law has buckets and center console I would like to swap in. anyone done this before? is it a direct bolt in?
thanks
i_live_in_canada is offline   Reply With Quote
Old 12-11-2018, 07:26 PM   #2
Re: 1990 chevy bucket seats swap
You'll have to drill holes for the buckte's inner mounts and the center counsole, but it is easy to do. I don't think the floor has any premade marking on it where you will need to drill, so just measure twice or so with the brackets, drill, bolt them in. I would use a hard thick washer or plate for the inner seat bolts to give it more strength in the floor mount support.
1981 GMC High Sierra SWB Stepside
Board Vendors
It's scary when you start making the same noises as your coffee maker.
Old 12-11-2018, 07:32 PM   #3
i_live_in_canada
thanks ill try that
Old 12-12-2018, 09:10 PM   #4
Sixball
I swapped buckets in my 94 that came from the factory with a bench. Use the risers as a template. I used thick plate steel underneath the body for reinforcement. The floorboards are actually thin
Sixball is offline   Reply With Quote
Old 12-13-2018, 01:11 PM   #5
sweetk30
selective wrench turner guy
sweetk30's Avatar
my old 96 crew cab floor had the threaded nut tabs welded on the bottom of the floor already . i just had to pop the hole threw the tin floor to get to them .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 12-22-2018, 05:51 PM   #6
YBNORML
YBNORML's Avatar
Same here. I did a Tahoe interior swap into my old 99í crewcab. Almost all of the corresponding bolt locations had dimples in the floor from above and a welded nut underneath.
I used 92 seat frame as I didnít have the wiring for the lower seats and they still lined up.
Jason.
Please note : Any items I have posted for sale are also listed locally and listing may end at any time.
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
Copyright ©2000 - 2019, vBulletin Solutions Inc.
